Engine fan running
Old 12 Mar 2013, 01:22 pm
Default Engine fan running
I know that in earlier post I had complained about my fan not running on the low speed. Thanks to these forums I was able to fix the issue and replace the fan. Now I seem to have the polar opposite problem.The fan is running all the time. I make sure the selector switch isn't on defrost and the blower is in the off position yet even after starting up first thing in the morning it comes on and runs. Is this a problem ? What could be some passable causes and fixes for this. I would hate to burn out that fan quickly. Thanks in advance for all the help again.
Old 12 Mar 2013, 01:28 pm
Default Re: Engine fan running
Maybe a relay stuck. Did it do that from the start? Is your temp gauge showing the correct temp. Yes it will ware out the new fan quicker. Did the plug look burned any?
Old 12 Mar 2013, 01:46 pm
The Temp gauge climbs to the middle and stays right where it should. The plug when replacing looked fine to me. what relay should i be looking at. I have a few extras from the junk yard. I dont think that they all would be bad.
Old 12 Mar 2013, 02:53 pm
Your not saying if the fan is running on high or low speed. You have an 05 so your PDC in the engne compartment looks like this:
You can clearly see the LOW and HIGH speed relays marked. One of them (HIGH) is the same as 5 other relays (including the horn) and the LOW speed relay is a little larger.
While the fan is running and nothing else is, pull the High or Low relay so the fan stops to see which one might be stuck.
Old 12 Mar 2013, 03:10 pm
If that fails to stop it then someone might have hot wired it somewhere. And you will need to check the wiring for this.
check engine light is on running good partyd General Turbo Discussions 11 15 Feb 2012 08:23 pm
Engine running hot JSRocket Tech & Performance Forum 10 29 May 2011 11:25 pm
engine running hot? myPTandME Tech & Performance Forum 2 06 Mar 2011 08:32 pm
Keys out of the ignition, engine still running... kyle_7600 Tech & Performance Forum 6 04 Feb 2011 05:22 pm
HELP! Key's Are Out, Engine Still Running! mentrc Tech & Performance Forum 0 04 Oct 2002 02:53 pm
