Rear Drum brakes on 2002 PT
Old 12 Mar 2013, 02:04 pm
Default Rear Drum brakes on 2002 PT
Can you guys tell me if the rear drum brakes on our PT's are self-adjusting?
If I back up and apply the brakes aggressively will it adjust the shoes? I used to be able to do that in my '88 Beretta, but wasn't sure if the same trick would apply to my PT. Thanks in advance for any answers that you can give me.
Steve
Old 12 Mar 2013, 02:33 pm
Default Re: Rear Drum brakes on 2002 PT
From the PT Do-It-Yourself.com: Questions and Answers.
Are the back drum brakes self adjusting when you back up, do they adjust themselves?
From the service manual - the rear wheel drum brakes are a two-shoe, internal-expanding type with an automatic adjuster screw. The automatic adjuster screw is actuated each time the brakes are applied. The automatic adjuster screw is located directly below the wheel cylinder.
Old 12 Mar 2013, 04:29 pm
All drum brakes are supposed to be self adjust. But if corrosion or service was done incorrectly then they may not work. If emergency brake holds you are probably OK.
Old 13 Mar 2013, 03:46 am
x2...
How to replace rear drum brakes? mycar Wheels, Tires, Suspension 1 02 Mar 2011 03:50 pm
Rear drum brakes? Miko General PT Cruiser Discussions 2 27 Jan 2010 08:37 pm
Converting Rear Drum Brakes to disc Matt42 Tech & Performance Forum 1 12 Jul 2009 11:01 pm
Rear Drum Brakes rszappa1 Tech & Performance Forum 5 04 Oct 2006 11:28 am
Complete Rear Suspension with Drum Brakes yellowpanel Classifieds: For Sale/Trade 0 09 Aug 2003 01:37 pm
