Power steering problems
Old 12 Mar 2013, 06:13 pm
Default Power steering problems
Well, my power steering has been making noise for some time now. The noise seems to be coming from the pump (passenger side of the car). The steering was working fine even with the slight noise. The other day, suddenly the power steering went out only at slow speeds. it's fine at higher rpm's (whether moving or not I need to keep the rpm's up to be able to steer). I've replaced the belt, flushed out the reservoir as best I could (Kinda hard to tell if it's clean or not due to the really small fill hole) and I replaced the pressure switch (fluid ran out freely when I took the old one out leading me to believe the reservoir is pretty clean).
Well, now the noise is constant. Worse when trying to turn the wheel and again, the power steering only works at higher rpm's. I'm leaning towards replacing the pump but, I'm wondering if maybe I missed something.
Anyone got any suggestions or am I gonna be replacing the power steering pump this weekend?
BTW. It's a 2001 PT touring with 196,000 miles
Old 12 Mar 2013, 07:17 pm
Default Re: Power steering problems
I believe you are there.
Old 13 Mar 2013, 02:48 am
Teska's Avatar
Yeah, with that milage I would look no further. Worn out pump. Mine does it too, a little hard at idle but works fine when revs go above 1000 rpm. So I 'm still sitting it out untill it's really undrivable. Have been doing 7000 miles of the faulty pump untill now
PT Cruiser 05 base 1,6 liter Electric blue.
Natural gas system build in.
Lowered with FK coilovers.
Installed Mopar sub !
Old 13 Mar 2013, 06:07 pm
OK. Well, I guess you two just helped make my plans for the weekend. I really thought that's what it was but wanted a second opinion before I wasted any more time and money.
Thanks guys.
Tags
power steering, power steering pump, steering pump
Power Steering Problems thatgirl1971 General PT Cruiser Discussions 12 24 Jul 2013 06:45 pm
Power Steering-it takes power just to steer it 05PTGT General Turbo Discussions 8 29 Jan 2013 08:37 pm
Power Steering problems 04PurplePT Tech & Performance Forum 3 03 Jan 2010 11:06 pm
power steering problems bluebeard Tech & Performance Forum 1 06 May 2009 07:07 am
Anyone that has steering problems... Please post nbr10 General Turbo Discussions 38 02 Feb 2009 10:24 am
