Help! I made a terrible mistake
  • 1 Post By PT_Panel
Old 13 Mar 2013, 07:35 am
Default Help! I made a terrible mistake
I had my 2004 PT Cruiser in storage for about 7 months, never intended for it to sit still for so long. Anyway, after replacing the battery it tries to start but just won't. It turns over but won't fire up. Any suggestions?
Old 13 Mar 2013, 08:02 am
Default Re: Help! I made a terrible mistake
I don't know. I have have a a 04 that has gas that is over 3 years old. It will fire up as soon as you turn the key. But just in case use some injector cleaner. You can pull a wire off the coil and hold it close to the hole while someone cranks to see if you are getting any fire. If so pull plug and check gap. If to wide and I mean more than a little. Regap to 40 and see if you do better. Won't hurt to clean the big grounds on the driver side inner finder. Try the key trick and see if you have any codes. Probably not since no running since you last unhooked battery.
Look at the top of this page for retrieving codes for the key trick.
Old 13 Mar 2013, 09:35 am
try using a little starting fluid. always works for me on cars that have been sitting
Old 13 Mar 2013, 10:36 am
PT_Panel's Avatar
Send a message via ICQ to PT_Panel
X2 ^
cruserdad1976 likes this.
06 PT LT Turbo, Back Doors welded in, Glass out, PTzed
Royal Mistake made, Ruined Convertible Top prowlerclone PT Cruiser Convertible Forum 35 23 Mar 2013 09:04 am
big mistake!!! wednesday The Detail Shop 4 07 Sep 2011 02:57 pm
mistake? slinger General PT Cruiser Discussions 3 19 Jun 2011 06:39 pm
dumb mistake o8bluept General PT Cruiser Discussions 9 16 May 2010 06:28 pm
