rpm drop while stoping
Old 14 Mar 2013, 06:43 pm
Exclamation rpm drop while stoping
i have a 2002 pt cruiser base non turbo ,,,recently change timing belt water pump spark plugs wires and coil , also air filter,wheel bearing,hub,both motor mounts and ill say after like 3 weeks from those repairs the engine started idleing bad when stop but when hit gas it runs smooth...... also would like to add ran smooth after time belt was on
Old 14 Mar 2013, 10:52 pm
Default Re: rpm drop while stoping
i'm gonna go with the radiator fan. they tend to go bad in our cars. i would also look for a vacuum leak.
2016 Kia Soul Plus Black
Old 15 Mar 2013, 04:51 pm
It doesn't run hot just idle down when stoping
Old 17 Mar 2013, 04:32 pm
cruisin03pt's Avatar
Well pt's seem to run kinda funny when vaccum is either low or high. I know that if you pump your brakes when youre stopped at a light, you can raise the rpm. I would check your break system and make sure your master cylinder and brake booster arent bad. Either that, or there is a vaccum leak somewhere.
Old 18 Mar 2013, 12:56 pm
Biggest vacuum leak issue that the PT has is the vapor canister.
After time it gets clogged, or springs a leak, thus not letting fuel vapors return to the gas tank.
This can cause erratic idle at a stop.
Costs like $75 and is pretty easy to replace, its located above the tranny, behind the battery box. Big black box :-D
Old 28 Mar 2013, 06:48 pm
i have this same problem the box you are talking about is it the solenoid on the fire wall or the canister by the gas tank i have a manual 02 pt with no engine code but same idle problem and it will stall to
Old 28 Mar 2013, 06:49 pm
Oh its by the firewall. Drivers side hidden way down in there. its not a small solenoid though. its a BIG BLACK BOX. 1/2 the size of your battery heavy too, its filled with charcoal.
Old 28 Mar 2013, 06:53 pm
i think thats next to my gas tank in the back i dont see it by the tranny
Old 28 Mar 2013, 06:55 pm
this?
Chrysler PT Cruiser Mopar EGR Vacuum Solenoid W0133-1875866 at Auto Parts Network
should look like this on the 01-02 model, 03 is 4x bigger so the one on your firewall is probably it.
Sorry for the confusion.
One on the gas tank should look like this
http://compare.ebay.com/like/2305979...Types&var=sbar
Check both of them for cracks or leaks, and the hoses connected to them
Drop in MPG tallbarb Tech & Performance Forum 5 14 May 2012 08:29 pm
MPG Drop jbcrzn General PT Cruiser Discussions 15 24 Jun 2010 10:30 am
Drop it like it's HOT 808 Wheels, Tires, Suspension 48 03 Sep 2009 02:11 pm
Drop top from Germany CREWZIN PT Cruiser Convertible Forum 0 03 Dec 2004 09:55 am
K&N drop in mcruz Turbo Wheels/Suspension/Handling 2 13 May 2004 10:11 pm
