coolant leak
Old 14 Mar 2013, 10:59 pm
Default coolant leak
I have had a small coolant leak for a while now, usually had to add a qt or so of coolant every 3000 miles or so. Well it recently got way worse, added a gallon of coolant in the last week. I pressure tested the cooling system and the leak appears to be coming from the area where the water pump mates up to engine. After reading a few threads I believe that it will be easier to also replace the timing belt and everything else while im in there for the water pump. My question is where do you guys get your parts for the water pump and timing belt job? do you get all oem parts from the stealership or just the autozone branded stuff?
2001 pt cruiser limited
2000 audi s4 built 2.8l twin tial 770r
2002 audi tt 225 quattro 35r
Old 15 Mar 2013, 03:33 am
Default Re: coolant leak
Buy quality stuff...you don't want to do this job twice. Use OEM or Gates and Dayco both put out complete kits that include the water pump...you will have to do a search to get the right part number for your specific PT.
Troubleshoot coolant leak: Photo of Coolant on top of engine radiator cap MarcusO Tech & Performance Forum 7 27 Apr 2013 09:16 am
Coolant Leak TimWeaver Tech & Performance Forum 6 13 Jul 2012 08:55 pm
Coolant leak Mikeliny Tech & Performance Forum 3 24 Dec 2010 08:36 pm
PLz help= Coolant leak PtC06 Tech & Performance Forum 2 04 Dec 2010 02:01 am
Coolant Leak dfales General PT Cruiser Discussions 7 18 Dec 2009 06:30 pm
