PCM Question
Old 16 Mar 2013, 01:38 am
Default PCM Question
Is the TCM inside the PCM...... If it is will it reset as well when you reset your PCM?
Old 16 Mar 2013, 08:10 am
Ray_Dockrey's Avatar
Default Re: PCM Question
It is separate but I would think unhooking the battery would reset it.
TCM and a ECM - Are they separate?
How to reset TCM? Error code P0700
Old 16 Mar 2013, 12:36 pm
Disconnecting the power will not reset the ECU/TCM, the information is in RAM and pending file so it will simply re-activate through cycling. It must be properly cleared and then if the anomaly was not corrected will return after the preset ECU/TCM cycling events.
:question:daytime running lights!!!:question: jrs61282 Tech & Performance Forum 10 07 Nov 2010 10:53 pm
Luggage Rack question and trailer hitch question Patrick_Dickey General PT Cruiser Discussions 5 26 Apr 2009 09:19 pm
