Help with one code
Old 19 Mar 2013, 11:28 am
Send a message via MSN to galeana77 Send a message via Yahoo to galeana77 Send a message via Skype™ to galeana77
Default Help with one code
Hello Guys, I was working on my PT this weekend to try to clear 2 codes that it has stored since some time ago.
First one was easy, P0550, I just changed the sensor and that clear the code away.
The second one P0172 System too Rich, is the one giving me some problems to figure out, here is what I checked:
1. Air Filter (changed).
2. Injector cleaner bottle put at the fuel tank.
3. MAF sensor cleaned.
The PT is running great, no stall, it recovers some power, in the past it had a little stall and was short of power when you start from stop, now run great.
Any idea of what can cause this code to shows up?
I have access to a live recording scanner, so if you want me to check something please let me know.
Thanks
Old 19 Mar 2013, 11:34 am
Default Re: Help with one code
these cars do not have a MAF sensor. you mean MAP?
I'd check the o2 sensors
you can read more here: P0172 Fuel Trim System Rich Bank 1
and here: Check Engine light code help
Old 19 Mar 2013, 11:49 am
Hey, thanks Rob I just check and I was mistaken, I didn't check the right sensor, thanks for let it me notice that, I'll take a look to that one and see if this is the cause.
Old 22 Mar 2013, 07:19 am
I had 5 codes all related to the same issue and that code was one of them. I just fixed it 2 days ago. I believe it the coild pack not firing correctly. My pt was running so rich i was using double the amount of gas. Now it runs great. I would try that first. I took the number 1 wire off and tested it at the coil pack. I paid $83 to get a new one.
Old 22 Mar 2013, 07:47 am
Hi Rob,
I have a problem and no one can seem to help me out. I put new t-stat yesterday fluched radiator, Fan is running, no water on the ground, and filled it with water. I let it sit in idle for 5 min and it started to over heat again. I have had this problem for awhile and cant figure it out. You have any suggestion?
Old 22 Mar 2013, 08:27 am
Hey Rob, tell him about trapped air in the coolant system.
Testing a variable speed radiator fan
CODE P0339 NOW, NOT "ALL" FIXED CODE YET HarleyTom Tech & Performance Forum 0 14 Nov 2012 03:23 pm
Code 340 Shellyellison General PT Cruiser Discussions 10 12 Dec 2010 05:19 pm
Code Help jennylyn General PT Cruiser Discussions 1 21 Sep 2009 01:57 pm
Code Help! 1lowufo Tech & Performance Forum 1 21 Aug 2004 07:03 pm
