The Wonderful P0340
Old 19 Mar 2013, 07:41 pm
Default The Wonderful P0340
Hey Guys, about a week ago on my way to my parents place the engine light came on, made it to their house checked code, got P0340, removed sensor cleaned put back in car, no code present.
Yesterday on my way home from work light back on, drove to gas station got a drink got back in my PT light off....on my way to work today light came back on, checked code P0340.
car: 2005 PT Cruiser Base
milage: 128,000kms
is this just the sensor? possibly wire rotage/breakage?
car still drives, not the greatest but you know.
Old 19 Mar 2013, 08:02 pm
Default Re: The Wonderful P0340
Has the timing belt been changed???
Old 19 Mar 2013, 08:07 pm
I had a cam sensor be great one day not start the next and start next.
Old 20 Mar 2013, 01:39 am
I'd go with a new cam sensor first. Also, check wiring and connector plug while there. Had an 03 chrysler [with a 340 code] that would start half the time normally, then would have to be cranked and stopped several times until the cam sensor syncronized with the engine. Then it ran great again.
Old 20 Mar 2013, 08:50 am
i am not too sure if the belt has been changed before, is there anyway to tell if it has?
This morning went to grab a coffee at the local Tim Hortons, when i got there the light was on, turned off car, grabbed coffee jumped back in and the light was off.
going to check the wires when i have some time, spoke with tech at dodge dealership he said to check the wires so thats what i am going to do, make sure there isn't any corrosion, his guess is that it is the sensor but you have to knock out the other possibilities.
Old 20 Mar 2013, 08:59 am
jrbsr05pt's Avatar
My sensor was off and on also. Just buy a new sensor. You can check the wires as you install it.
2005 n/a 5 speed. 177365 miles. spectre cold air intake, white and pink leds under dash and back seats, purple leds in vents, wall with 1 18" subwoofer built behind back seat(soon to be either 16 American bass vfl8's or 4 18's with the wall rebuilt all the way to behind the front seats,cant wait!!!), blue dash lights, pink turn signal indicators. 3D tails and tinted backup lights. Power antenna (that no longer has power ha!) another one gone but wont be forgotten
2003 gt turbo. 130245 miles. autostick, mopar riceplate, 3" o2 housing and downpipe. custom diablo tune (totaled, gone but not forgotten)
2003 dream cruiser. autostick, mopar body kit, mopar bov, cai. s1 injectors. mopar s1 pcm. 3" 02 housing and downpipe installed from last turbo, upper IC hardpipe more on its way soon.......... diablo tuner in the near future.
Old 20 Mar 2013, 09:25 am
A code is placed in RAM or pending until corrected and cleared properly. I would suggest you get the code cleared and then see if it returns.
You may also have other codes that you were not aware of, so vewiing them may help to solve your issue. The "key dance" often does not display code(s) in a pending file.
Old 09 May 2013, 07:05 pm
I need help too 01 pt with p0340 code, changed
cam sensor
crank sensor
tim belt
mag on cam
found a few broking wires in cam sensor and crank sensor harness and repaired them
here is the funny thing car ran for 15 min the quit and had to wait to cool off
now after replacing starter, no spark has anyone found abroken wire besides the crank sensor area?
also does anyone have the cam sensor wires function like the orange is power ect.? thanks
Old 09 May 2013, 07:40 pm
Maybe this will help...
Enjoy MTS Files on your players (wonderful mts converter)ui xigu786 General PT Cruiser Discussions 0 29 Nov 2010 10:24 pm
