2003 oil sensor problem code 522
Old 26 Mar 2013, 11:49 pm
Default 2003 oil sensor problem code 522
We have a 2003 mint PT cruiser with 35000 miles. I'm getting a 522 error code which is low input at sensor, we have replaced the sensor twice and the oil light comes on one out of 10 times that we drive it. So what is next, check the pressure with a pressure gauge. I just can't imagine it being a bad oil pump but hell what do I know. any advice is welcome.
Old 27 Mar 2013, 04:43 am
Default Re: 2003 oil sensor problem code 522
If dipstick level is ok, then check the oil pressure with a mechanical gauge. You want to know the pressure at: cold idle; cold 3000rpm; hot idle; hot 3000rpm. Hot means you cannot hold your hand on the oil pan.
Old 27 Mar 2013, 05:15 am
Are you replacing the sensor with a Genuine MOPAR part? Our PT's don't like sensors from the auto parts store.
Tags
522, light comes on, oil pressure
O2 sensor fault code davea300 Tech & Performance Forum 14 11 Apr 2015 12:54 pm
p0522 code engine oil pressure or sensor voltage 2003 PT oldorange General PT Cruiser Discussions 1 13 Oct 2012 03:34 pm
O2 Sensor - broken but no code? Boulty Tech & Performance Forum 2 03 Dec 2010 04:49 pm
Cam Sensor code changed sensor still dead RottenKid Tech & Performance Forum 8 18 Nov 2008 08:17 am
MAP sensor & code 108 twoyacks General Turbo Discussions 0 13 Sep 2008 05:51 pm
