Coolant leak question
Old 27 Mar 2013, 02:22 am
Default Coolant leak question
Hi Experts/PTsters,
I drive a 2006 Pt Cruiser Touring edition and I had a question regarding coolant circulation in my PT. Does the coolant start to circulate as soon as the car is started or it starts to circulate after the car is stopped? The reason for the question being, my car is leaking coolant and I can see it leak on the ground only after I shut the car down after driving (even after little bit of driving).
Thanks
Old 27 Mar 2013, 04:25 am
Default Re: Coolant leak question
The coolant always circulates in the engine and heater core. It only circulates thru the radiator when the coolant at the thermostat reaches say 195 degrees.
After the engine is shut off, the heat from the engine continues to increase the coolant temp for a while.
Old 27 Mar 2013, 07:55 am
Question Re: Coolant leak question
Check the overflow line for loose and the plastic filler neck and cap for signs of white looking residue. A sign of a leak.
Old 27 Mar 2013, 07:53 pm
I cannot see any leak or residue from above. However if I am facing the car and kneel down facing the radiator I do see it collecting where the small tube attaches to the radiator at the bottom and then it seeps from there. This only happens after I turn off the engine.
On a different note do you recommend having brake flush service at 92000 miles? It was recommended by a car repair shop. Just wanted to find out it is necessary maintenance service or just an extra service recommended by car repair shops.
thanks
Old 27 Mar 2013, 09:12 pm
what city/state do you live in?
Old 27 Mar 2013, 09:21 pm
you'll really need to get a flashlight and poke around. if you see where it leaks or white streaks where it's drying, take a picture for us.
for your other problem, do you know where the brake fluid goes? i wouldn't bother changing it unless it was black
Old 27 Mar 2013, 10:39 pm
UptownSport's Avatar
Get out owners manual or search here and download one.
It will tell you what needs to be done and when for maintenance
Old 28 Mar 2013, 07:15 am
I live in columbia, MD
Old 28 Mar 2013, 07:21 pm
Get a flashlight and see if you can find a leak at any point above that lower hose, if you cant its either the hose itself has dried out and cracked at the intake to the radiator, if so drain the radiator, disconnect the hose and replace it. Use hose clamps to get it on real tight.
If its not cracked then the discharge plug that is used to drain the coolant is leaking.
you can replace the drain plug for like $5. Odds are the threads are worn and are just letting coolant out
Hope this helps.
Old 28 Mar 2013, 08:05 pm
I used to live in Columbia, Maryland. In the Village of Owen Brown to be exact.
Troubleshoot coolant leak: Photo of Coolant on top of engine radiator cap MarcusO Tech & Performance Forum 7 27 Apr 2013 09:16 am
Coolant leak Mikeliny Tech & Performance Forum 3 24 Dec 2010 08:36 pm
Got a mechanical question on coolant bottle leak: Candyman Tech & Performance Forum 4 08 Jun 2010 06:25 pm
Coolant Leak dfales General PT Cruiser Discussions 7 18 Dec 2009 06:30 pm
Coolant Leak rcalzadilla Tech & Performance Forum 29 25 Oct 2009 01:29 pm
