TEMP GAUGE READING TO LOW
Like Tree13Likes
Old 28 Mar 2013, 03:45 pm
Default TEMP GAUGE READING TO LOW
Its had the sensor changed as well as thermostat. No change. Idle is high arount 11 to 18k. Have had the p0128 on accausation. Swapped the AIC nothing. can't find any vac leak. Throttle rod setting against the adjuster. So doesn't appear to be tps.
03 n/a .
Old 28 Mar 2013, 06:26 pm
Default Re: TEMP GAUGE READING TO LOW
03 n/a .
Try out a higher rated temp thermo. I had the same issue, blew through 6 thermostats in 3 months thinking they were sticking open and i was just cycling through thermos.
Turned the weather was cooling the coolant in my radiator so fast that by the time the thermo opened i was shooting ice cold coolant into the block, thus keeping the temp guage below the 1/2 mark all the time, and when it did go up to 1/2 it had been after about 2 hours driving. Threw in one rated a few degrees higher than OEM and havent seen the issue since.
Old 28 Mar 2013, 06:56 pm
Mine is only going up the first line from the bottom. About one third of normal. All the heat you can stand.
Old 28 Mar 2013, 07:01 pm
Check all the hoses for a blockage as well. Might help ya to have a power flush done to the radiator. To be running that cold it sounds like there is NO thermostat, but we know thats not the case.
Only thing i can think of is the coolant is getting stopped up on the intake from the radiator into the block. If it was on the return you would have overheating i think so.....yeah check everything out down there.
Another easy trick is dilute the coolant a bit with water, will cause it to heat faster, and maybe give it a chance to warm up.
Do you use pre diluted 50/50 or do you dilute it yourself? I've accidentally added to much straight coolant to the mix before and had heating issues.
Old 28 Mar 2013, 09:04 pm
Mix my own. Hot everywhere. All hoses ,heater, and reading from my scan tool 159 to 165.
Old 29 Mar 2013, 01:59 am
UptownSport's Avatar
It IS getting hot, just not reporting correctly. I'd assume in WV it's not Minnesota / Maine frigid ever ...
I'd ensure it's a Mopar sensor for your specific vehicle (two sensors can be EXACTLY the same externally but have different internal values.)
IDK what else could cause this. I recall a Lady at work who had this problem, I brought her a new sensor (I had before I owned a PT; don't ask) but she'd traded it.
Old 29 Mar 2013, 04:25 am
I would change the thermostat again. Mopar and Stant used to be quality products. Burp the system. Your gauge should read halfway after 5-10 minutes of driving. The idle is a different issue. A stuck pcv valve might cause it.
Old 29 Mar 2013, 04:26 am
Get a hand-held non-contact infrared thermometer and with the engine as warmed up as you can get it, aim it at the thermostat housing...should read approximately the thermostat rating (195F according to the repair manual). Aim it at the upper radiator hose near the thermostat...should read about the same.
Old 29 Mar 2013, 04:30 am
Just wondering if the idle is too high because the PCM thinks the engine is too cold ???
Old 29 Mar 2013, 07:16 am
Had three different sensors in it. Not sure if any were Mopar. But no change so far. Might have to consider that. Yes on the weather. Doesn't seem to matter. Heater warms up in timely fashion.
The thing is I put a new stant t stat in and looked as if it had already been changed. Found original owner and he confirmed. he had tried the sensor a while back same results. Will check the PCB.
That was a thought I had. But the TPS doesn't move the throttle plate. It's just sitting on the set screw. Far as the idle goes I'm going to try something Nitro suggested. Putting my hand over the throttle body to rule out any chance of a vac leak. If it doesn't die straight off. Then it has to be sucking air somewhere? Thanks everyone and keep throwing out any ideas you have. I am going to see if I can come up with a infrared or temp probe to test it manually.
06 PT temp gauge issues Humbert200 Tech & Performance Forum 3 31 May 2012 06:06 pm
Temp gauge please help Cyclone35 General PT Cruiser Discussions 4 18 Feb 2011 02:58 pm
Outside Temp Gauge Jeff V General Turbo Discussions 20 13 Dec 2010 06:00 pm
compass/outside temp reading bandbpt General PT Cruiser Discussions 6 05 Jun 2008 03:36 pm
Reading for A/F Gauge DaShado Tech & Performance Forum 3 23 Mar 2007 11:13 pm
