Timing Belt Tensioner installation 2002 PT
Old 30 Mar 2013, 07:35 pm
Default Timing Belt Tensioner installation 2002 PT
2002 PT with 2.4L. This one part is killing me. I canít seem to get it on right. After multiple attempts, I got the Tensioner bolt on one way and didnít seem like I had enough room to get the timing belt on. SO I removed it to try again. So using the pictures provided, how should this Tensioner be lined up the socket it bolts into? I already tried the flat side of label ďAĒ in photo to ď1Ē of socket.
Thanks Kevin (South Eastern PA)
Old 31 Mar 2013, 12:23 am
UptownSport's Avatar
Default Re: Timing Belt Tensioner installation 2002 PT
Kevin, if it was on, that's the way it's supposed to go.
I'd put belt on, then install tensioner, you can 'walk' belt over top gears if you need to adjust a tooth or two.
If everything goes smoothly and it seems right, it's guaranteed wrong-
Not a fun job!
zamfir2 likes this.
Old 31 Mar 2013, 10:11 am
Thanks I guess I'll try again, just need some more patience. I was going to lose it yesterday.
Old 14 Nov 2013, 11:40 am
KROD,
I'm having the same issue. Were you able to get the belt back on? When I install the tensioner, my belt goes about 2/3 of the way and is very tight attempting to get it over the tensioner which also makes it very hard to keep the timing marks aligned. Spent about 2 hours last night pulling the tensioner off and back on again, realigning timing marks and attempting to get the belt on.
Old 15 Nov 2013, 02:56 am
krod; from the pics and a manual, I believe there is a 'tensioner assy' V- shaped arm that goes in your 2nd pic hole first. Then the tensioner pulley gets bolted to that. Leave the pull pin in place until the belt is on. --- a 1/8" allen wrench can be used if you loose the pull pin.
Busted; help me out here. You da man!
Old 15 Nov 2013, 03:03 pm
pt06,
I have the same set up as krod. The tensioner is supposed to be the OEM replacement for the one that was pulled off. That's all that came off of the engine was the tensioner with no bracket. I just tried putting the belt on again and it is just a fraction from going over the tensioner. Very frustrating.
Old 15 Nov 2013, 04:14 pm
I have not jumped in because I haven't used a first design kit. Most convert to the second design on here. Other than using a wrench to pull the belt to the tensioner side to get all the slack they can. Not sure if I have anything relevant.
Old 15 Nov 2013, 04:37 pm
Hey Busted,
Does the upgrade make it easier to put the belt on? Also, reading the posts, do I have to remove everything and modify the plastic cover to install it?
Old 15 Nov 2013, 06:03 pm
OK, belts on......funny how it just takes someone mentioning something in their post that joggles the mind. Once I got the slack out of the belt from the other side I had enough to slide the belt over the tensioner. Spun it around several times and all of the timing marks are aligned. Now to see if she fires up. Great forum.
Old 15 Nov 2013, 09:42 pm
Great to hear, i love happy endings. I would take good detailed pictures. of the engine with the timing marks lined up. for reference further down the line just in case problems crop up. The pic can help rule out possibilities. If someone says is the timing right. You got pic to prove one way or another.
Timing Belt Tensioner ? SteveG22 Tech & Performance Forum 11 19 Sep 2012 12:46 am
Timing belt tensioner? unioncreek Tech & Performance Forum 1 20 Jul 2012 12:00 pm
Timing belt tensioner Jeepertim Tech & Performance Forum 9 25 Nov 2011 12:39 pm
Timing belt tensioner slimjonesy General PT Cruiser Discussions 0 19 Mar 2011 06:35 pm
Timing Belt Tensioner 06ptbruiser Tech & Performance Forum 11 31 Dec 2010 10:39 am
