radiator fan
Old 31 Mar 2013, 07:25 pm
Default radiator fan
I have a 2006 base model...Does the cooling fan only come on when the ac is turned on?
Old 31 Mar 2013, 07:34 pm
Ray_Dockrey's Avatar
Default Re: radiator fan
It is a two speed fan. It is really hard to hear or see it running on low but when the AC is on it will run on high and you can definitely hear it. Are you having an overheating issue?
Old 31 Mar 2013, 07:49 pm
Dino's Avatar
Our fans are a major weakness, the fan should always be on when the AC is on but should also kick up to high when your at a light or something. You can always here it kick on to high speed. When it doesn't kick to high speed the bushing in the fan may be shot. You can get fans on ebay cheap or at a place like advanced auto. No reason to buy the Chrysler one since they suck anyway. We also have instructions to change it in this very sub forum in the stickies.
http://www.ehow.com/how_5895154_remo...t-cruiser.html
Old 01 Apr 2013, 09:26 pm
Thxs for the info.....I think I am over heating a bit......should the thermostat lever stay exactly between hot and cold?
How can I tell if it is overheating?
Old 01 Apr 2013, 09:36 pm
The link Dino posted is on removing the radiator which is a lot of work you don't need to do. Here is the link to replacing the fan. It is for a 01-05 but it basically the same in the 06. I used them to replace the fan in my daughters 06.
The temp gauge on all the PT's I have seen run just below the midway point.
Old 06 Apr 2013, 05:25 am
I'm with Ray. 5-10 minutes to reach half-way and then stay there. The fan is turned off and on independently by either the AC as needed or the coolant temp as needed.
Old 28 Dec 2013, 11:43 am
i am not sure why but my fan stays on sometimes after I turn the car off... I tried changing the battery, which worked last time. Is there some relay or switch or basically a simple fix? I can't afford any major repair issues right now.
Old 28 Dec 2013, 02:26 pm
You need to tell us what car your driving. There's a difference in electrics between the 01-05 and 06+ cruisers. Your problem might be as simple as a stuck relay (high or low depending on the fan speed that's running) or as bad as the computer malfunctioning but that could be easy also if it only needs a reset.
First thing to try is disconnect the negative battery cable for 10 minutes to see if that helps.
Old 28 Dec 2013, 04:09 pm
it's an 07 Cruiser.
I have tried the disconnect thing before.
It does shut of the fan, but it still does this intermittently. I have found if the car runs for 15-20 minutes it seems ok, but the short 5 minute trips are when it seems to stay on. It isn't over heating or even coming close to that. runs like normal, temp is normal, it's just the fan staying on.
Old 28 Dec 2013, 04:21 pm
The newer 2nd generation cruisers (2006+) have a whole different electrical system called the CAN-BUS and that's a whole new kettle of fish when trying to diagnose a problem. The older cruisers, in the fuse box, there were high and low relays you could check ...not in the new ones. I can't help you more than I've already said. Maybe someone else that's more familiar with the new electrical system will pop in and give you more advice.
Last question; Did you wait around for awhile to see if it would ever shut off? My Corvette fan stays on after I shut the engine down until the coolant reaches a particular temperature set by the computer. Might take a minute or 10 but it does shut off eventually.
Which radiator fan is best? 32seventeen Tech & Performance Forum 12 23 Jun 2012 10:09 am
The radiator fan [again] bogaz Tech & Performance Forum 43 23 Aug 2011 06:43 pm
When Should Radiator Fan Come On? duffner General Turbo Discussions 17 16 May 2011 08:49 am
03 PT Radiator Fan 03PTDriver General PT Cruiser Discussions 7 23 Sep 2010 03:43 pm
radiator sandylolee General Turbo Discussions 2 06 Jun 2009 11:10 pm
