2002 pt cruiser overheating
Old 01 Apr 2013, 01:45 pm
Unhappy 2002 pt cruiser overheating
I need help. Trying to make my car last 6 more months. It start overheating only when I was stoped. Since then I have had 3 people work on it. I have no white smoke coming out which I'm told would indecate a head gasket. I have had 2 different thermo put in, new radiator, pressure test, new hoses and the water pump check (the said that was fine). I put water in and can go about 10 miles shut the car off then i girrles. I then lose water coming from the reserve bottle. I have spent $600 dollars so far and money is tight. Can anyone give me some hints?
Thank You
Old 01 Apr 2013, 02:03 pm
Default Re: 2002 pt cruiser overheating
You didn't say anything about changing the radiator fan and that's the No#1 cause of the PT Cruiser overheating. The second would be a clogged radiator. Other causes include having trapped air in the coolant system. It needs to be bled of all excess air to run properly and not overheat.
Old 01 Apr 2013, 03:03 pm
A loose fitting over flow hose will loose coolant and suck air back into the system.
06 Cruiser overheating Wutliss420 Tech & Performance Forum 1 21 Feb 2013 03:43 pm
2002 pt cruiser keeps overheating air doesnt work please help ashleyp92 General PT Cruiser Discussions 3 12 Aug 2012 08:55 am
2002 Cruiser Overheating someguy Tech & Performance Forum 2 07 Aug 2011 07:10 am
2002 PTC Overheating story, happy ending. FrancoRios General PT Cruiser Discussions 0 03 Nov 2010 09:22 pm
'02 Cruiser Overheating- Please Help sparker723 Tech & Performance Forum 7 31 Jul 2010 08:44 pm
