Transmission leak?
Old 02 Apr 2013, 07:08 pm
Default Transmission leak?
I took my 2002 PT to the dealership to have the turn signal/light assembly fixed. OK, they replaced it and that's fine.....BUT, they told me I had a leak at the transmission solenoid. (Changed the tranny fluid at around 52,000 miles and only 58,000 miles on it now.)
Here's the thing though. I don't believe them. Have had NO transmission problems and park in the same place in our garage every night. There are no drips, drops, or smudges of any kind of fluid on that garage floor. Wouldn't it actually have to leak to see that it's leaking??? And how does one detect a leak under the car when all they're supposedly doing is replacing the turn signal assembly?
Old 02 Apr 2013, 08:09 pm
Default Re: Transmission leak?
I could be wrong about this.....they had to/should have disconnected the negative battery cable to work on the light system. To disconnect the cable, they had to take the air filter system apart. I believe the trans solenoid is under all that so maybe they could see it was leaking that way. ???
Transmission seal leak rcalzadilla Tech & Performance Forum 2 17 Mar 2013 02:12 pm
Transmission leak Encara2 Tech & Performance Forum 6 01 Feb 2013 07:15 pm
Transmission leak above oil pan calcuaz General PT Cruiser Discussions 4 21 Dec 2010 09:21 am
Transmission leak!!! Milowe General PT Cruiser Discussions 1 17 Jun 2008 03:44 pm
Transmission leak macster Turbo Performance 17 25 Jan 2004 05:38 pm
