P0344 AGAIN?
Old 04 Apr 2013, 11:59 pm
Default P0344 AGAIN?
05 pt cruiser 2.4 no turbo
what would be my next step?
replaced head gasket, timing belt, oil pan gasket, oil pump seal.
car didnt start right away and came up with ckp and cmp codes.
after cranking for a while and checking everything finally started
in limp mode so no rev above 2300 rpm or so.
changed cmp sensor and same problem
code pops on immediately from cranking
rechecked timing marks
tested cmp sig to pcm and works
tested ckp sig to pcm and works
ckp and cmp sync was at 8 deg before i replaced cmp
now at 0.0 but seems as though the computer is not seeing the cmp runs same with plugged in or unplugged
no signal on scanner from cmp even though its firing at pcm connection
any ideas?
Old 05 Apr 2013, 07:32 am
Default Re: P0344 AGAIN?
Duffy, are you using Chrysler sensors or aftermarket? Our PT's don't like aftermarket (auto store) sensors. They may look the same as genuine MOPAR brand but they don't last as long and some don't work at all.
Old 05 Apr 2013, 10:11 am
Dealer was closed. Used Napa part. But then installed the original one it had on it before I started. The car ran fine before. I replaced gaskets due to leaks. I've also taken the timing belt back off and reinstalled again even though the marks were lined up. Still same thing. The sensors cmp and ckp have ground, 5 volt reference, and signal at the pcm.
Old 05 Apr 2013, 10:15 am
I am going to try new Chrysler sensors .. But why would they go bad like that?
Old 05 Apr 2013, 11:58 am
May not be the sensor, but the magnet inside. They don't get changed with any new sensor.
Old 05 Apr 2013, 01:07 pm
Magnet looks good. New sensors did nothing. Timing belt round three happening. The marks line up straight across all four marks right?
Old 05 Apr 2013, 02:02 pm
Had a picture but apparently it was no good.
Old 05 Apr 2013, 08:58 pm
Smile Re: P0344 AGAIN?
Timing marks were off then according to your picture. Reset the belt to the picture. Still same problem. Just to eliminate.. Put on new magnet.
Now runs great.
Problem fixed.
No visible cracks, marks, or other problems. Still magnetic so i dont know what happened but it is fixed.
Thanks for the input.
Old 05 Apr 2013, 09:54 pm
Glad you got it going.
Old 06 Apr 2013, 05:48 am
Crewzin: Excellent pics of the sensor and magnet. Easy to understand. Also, remove and clean the magnet; as any metal in the magnet will 'confuse' the cam sensor.
03 PT with p0340 and p0344 need help. sufe70 Tech & Performance Forum 25 22 Aug 2016 02:49 pm
03 with P0325 and P0344 PTinCO Tech & Performance Forum 8 17 Feb 2015 09:07 pm
P0344 FMTPTCREWZER Tech & Performance Forum 6 14 Sep 2012 02:29 pm
p0344 carolinagirl Tech & Performance Forum 2 15 Aug 2011 05:48 pm
the dreaded p0344 code ev3 Tech & Performance Forum 8 02 Apr 2011 02:44 pm
