08 BASE PT cruiser 2.4 NO START!? HELP!!!!
Old 05 Apr 2013, 02:33 pm
Default 08 BASE PT cruiser 2.4 NO START!? HELP!!!!
hey everyone im chris and I have a small situation on my hands! im just about to lose what lil hair I have left, 08 cruiser I just replaced the head gasket. the car ran but was overheating I replaced all necessary gaskets associated with replacing headgasket, now it wont start not sure what I did wrong here. I have fuel but no spark to plugs, connector has fire as well so I pulled away one of the coil boots an hooked up my multi meter an no volts. replaced coil and still no volts. any suggestions?
Old 06 Apr 2013, 02:11 pm
Chriscokid's Avatar
Default Re: 08 BASE PT cruiser 2.4 NO START!? HELP!!!!
Pt's are a peculiar vehicle. I'd try taking battery cable off for 5 minutes to reset PCM . Also step on brake pedal for thirty seconds to drain residual power before replacing cable.
Hope this helps
[SIGPIC][/SIGPIC]2005 PT GT Vert
2004 Honda Aquatrax turbo Jetski
2006 Honda Aquatrax
1998 Dolphin 36' motor home
1949 Piper Clipper taildragger
Old 06 Apr 2013, 03:50 pm
ok thx for replying, I just tried and still got no start. im just confused about this whole thing, the coil connector shows source voltage but its not sending fire through the wires to the plugs. what else could it be?
Old 07 Apr 2013, 03:12 am
The coil fires the plugs when the computer grounds out the circuit. The computer grounds out the circuit when it receives signals from both the cam and the crank sensors [and others]. Don't use your meter at the plug wires!!!!
Old 08 Apr 2013, 08:06 am
ok so possibly the cam/crank sensors aren't sending a signal?? how do I test them?
Old 08 Apr 2013, 08:18 am
Ray_Dockrey's Avatar
Are you getting any codes? Has it ever started after replacing the head gasket? If it is a cam or crank sensor then it will have set a code.
Old 08 Apr 2013, 08:21 am
wouldn't start after I put everything back together, no codes at all
Old 09 Apr 2013, 01:27 am
Recheck for broken wires or bad connections?
Old 09 Apr 2013, 03:28 am
x2...
Old 09 Apr 2013, 07:49 am
I did a whole engine compartment sweep, found nothing wrong but as I was sleeping last night something came to mind. I had the head sent to a machine shop to be checked and re conditioned, they sent it back with a powdered coating on the head an I figured maybe this is keeping the head from grounding the plugs, so I took a wire brush to the ground meeting surface and cleaned it up rehooked the ground an still no start so this morning im sending it to the dealership. ill repost what has happened and maybe this thread will help someone later on down the line. I appreciate everyones help in this matter thx a lot an keep those pt's running!!
2004 PT Cruiser Base ecrazee Welcome New PT Cruiser Members 12 09 May 2012 09:13 am
PT CRUISER vs Challenger(base) mjb457 General PT Cruiser Discussions 4 26 Mar 2011 08:46 pm
2004 base model Crusier won't start rjr Tech & Performance Forum 7 24 Oct 2010 02:15 pm
Parting Out 2005 PT Cruiser base base model taftboys Classifieds: For Sale/Trade 9 07 Oct 2010 07:13 pm
No start - 2001 base model bobdole369 Tech & Performance Forum 8 05 Mar 2009 08:58 pm
