Please Help!! Issues with my 05 Cruiser
Old 06 Apr 2013, 04:31 pm
Default Please Help!! Issues with my 05 Cruiser
Hi all. New to the forums and I was hoping someone could solve my issue. I have an 2005 base model auto with 126,000 miles. l was recently having a mis-fire while driving and at idle. I thought it was a timing belt so we changed that. Changed the spark plugs and wires just for good measure. Put everything back together and it wouldn't start and run with out help. Got it to keep running above 2000rpm it gave us a crankshaft error. Replaced that then got a MAP sensor error. Replaced that then got a Throttle Position sensor error. Replaced all of that and it still misses. Checked for spark and vacuum leaks. all were fine. I was debating replacing the PCM but I didn't think that i would get CEL's or that the engine would run if it was failing. Also replaced the IACV as another member wrote it would solve the idle miss.It helped but still having a miss. I'm not receiving any other CEL codes now as well. I've been a month without my car, any help you can provide would be greatly appreciated!!
Old 06 Apr 2013, 04:56 pm
Ray_Dockrey's Avatar
Default Re: Please Help!! Issues with my 05 Cruiser
Are you sure you got the timing right? It is very tricky on these cars.
Old 06 Apr 2013, 05:04 pm
Yes, my husband is pretty observant and kinda anal retentive about making sure everything goes back together correctly. He is double checking the timing belt alignment, but in the instance it is correct, do you know what else may be causing my issues? Thanks for responding!!
Old 06 Apr 2013, 05:45 pm
Sounds like there's only two things you having checked or replaced; the camshaft sensor and the coil. There should have been a fault code to helpyou pin point it but who knows. The coil is pretty bullet proof but we have seen one or two get replaced and fixed the problem. On the other hand, the camshaft position sensor is notorious for going bad or the wiring harness that it's attached to.
Cruiser Control Issues. Crid General PT Cruiser Discussions 5 01 Apr 2012 01:54 pm
01 PT Cruiser starting issues rampagent69 Tech & Performance Forum 1 28 Jun 2011 09:12 am
another pt cruiser with issues. neogeo Tech & Performance Forum 13 04 Jan 2011 06:01 pm
Help Issues With PT Cruiser sml18 Tech & Performance Forum 4 24 May 2010 08:36 pm
Cruiser AC Issues mscaho Tech & Performance Forum 4 16 Jul 2007 11:20 pm
