Mount problems - engine alignment
Old 07 Apr 2013, 01:52 pm
Default Mount problems - engine alignment
I decided to change the lower torque strut, but found out the upper one isn't aligned properly IMO.
I talked to my mechanic and he said that it looks like the engine is moved into the passenger side, and that the movement might be on the transmission mount, so I assume there might be a possibility to align it on that mount?
Does anyone know how to align the engine? I don't really wanna change the lower strut, cause I know that the whole thing is moved...and probably the new one is going to torn down very quickly...
thanks in advance!
Hubert
Old 07 Apr 2013, 01:57 pm
Default Re: Mount problems - engine alignment
The center mount you can't see determines the alignment,side to side. The top mount might be flipped over.
Old 07 Apr 2013, 02:18 pm
Thats what I thought about flipping it over, but how can you do that as a mechanic (I assume)...I should remove it and check.
About the center mount - do you think it might be the one that caused the movement? that far?
EDIT: found this vid
and it looks pretty clear that there is much more space between the engine and the upper mount bolt....there need to be the way to move the engine...
Old 07 Apr 2013, 02:43 pm
Third mount is in the frame rail and is not adjustable.
Old 07 Apr 2013, 02:50 pm
This is the wrong mount. This mount has a slotted hole instead of round. See how the rear of the mount sits closer to the engine than the one in the picture. The other end could be to long as well.
Old 07 Apr 2013, 03:09 pm
Third mount - which one you reffer to? the lower one behind the belt platic cover?supposedly the mount that is by the trans is adjustable but I don't know that....
I just relized that on my pic you can see that after loosening the bolt that hold the mount to the frame, I might be able to adjust it (if I have slotted hole) a little bit to the outside...
but still it won't get to the perfect alignment.
Old 07 Apr 2013, 03:26 pm
It's not supposed to have that slot. The third mount is in the middle of the motor half way down towards the lower mount. The bolt for it is located in the finder well under a rubber plug.
Old 07 Apr 2013, 03:46 pm
and its adjustable?
Tags
alignment, transmission mount
how to fill your engine mount rob342 Tech & Performance Forum 44 06 Sep 2014 07:04 pm
Top Engine Mount! mdfrodolives Tech & Performance Forum 6 18 Apr 2011 08:04 pm
ok how do you get the top right engine mount out??? llcelebrity Tech & Performance Forum 6 20 Feb 2009 11:44 am
Engine Mount Problems chris1916 Tech & Performance Forum 1 15 Jan 2009 03:19 pm
Roof alignment problems skylight PT Cruiser Convertible Forum 1010 20 Sep 2006 09:35 am
