Car stalls.
Old 07 Apr 2013, 11:11 pm
Default Car stalls.
2002 pt cruiser. The car idles fine in park and revs up normal. However if the car is in reverse or drive and give it gas the car will stall pretty much every time. Once you do get it to go it drives normal and doesn't stall while driving. Like i said if you put it in gear with your foot on the brake and give it a little gas it will stall. The motor was just installed in this car and from what i was told the spark plugs were changed, i cleaned the idle air control. Not sure what else was done to it.
Old 07 Apr 2013, 11:17 pm
Chriscokid's Avatar
Default Re: Car stalls.
We once had a similar problem with a Toyota corolla. The muffler was stopped up and it would intermittently produce power. It would run fine in park when there was no load on engine. It could also be cat. Converter. Some of the other guys may chime in with other suggestions.
Also welcome to forum
[SIGPIC][/SIGPIC]2005 PT GT Vert
2004 Honda Aquatrax turbo Jetski
2006 Honda Aquatrax
1998 Dolphin 36' motor home
1949 Piper Clipper taildragger
PT Stalls After Getting Off High Way rich09 General PT Cruiser Discussions 15 09 Apr 2011 06:00 pm
'03 Cruiser Stalls, Won't Start bjagd02 General PT Cruiser Discussions 5 22 Feb 2011 06:33 pm
Loud Pop then engine stalls golddust General PT Cruiser Discussions 4 18 Nov 2010 07:50 am
2.4 5speed stalls raceu2 General PT Cruiser Discussions 2 02 Jun 2009 11:56 am
stalls when slowing to stop codfather General PT Cruiser Discussions 12 17 Oct 2005 12:39 pm
