misfire,code po300 po304
Old 08 Apr 2013, 09:13 pm
Default misfire,code po300 po304
ok I am new to this forum. I have a 2005 2.4l turbo,started to misfire at idle and hiway speeds. Changed plugs wires, coil,cam position sensor. Still has misfire,checked coil output with tester and all cylinders are receiving spark. all injectors appear to be working,with the screw driver method, all clicking. I have sprayed starting fluid around intake manifold with no change in miss. Have not done a compression test yet,but why would this all of a sudden start with no previous indications. Getting very frustrated,starting to dream about matches and gas cans..lol:
Old 09 Apr 2013, 05:17 am
Default Re: misfire,code po300 po304
Did you use a Mopar cam sensor? Lots of aftermarket sensors don't work.
Old 09 Apr 2013, 02:02 pm
Yes I used a mopar sensor.Today it seems to run better but am getting a flashing check engine light at idle,does not seem to be missing now under load. when I say missing at idle it doesn't do it every time. I used bosch platinum plugs , could the plugs be giving me issues? This is getting to be very frustrating. I am going to change intake manifold gaskets and valve cover gaskets on the week-end,I notice a small amount of oil in spark plug tubes so it is starting to leak a bit.Thanks for any help
Old 09 Apr 2013, 08:25 pm
Mine is doing the exact same thing. I am thinking intermittent injector failure.
Old 10 Apr 2013, 05:05 am
Flashing check engine light is serious - what code(s)?
Old 10 Apr 2013, 10:10 am
I have similar issues, I just deal with it. I don't think theres much left to try/replace/etc for mine, but you can try and make sure you have a good ground and positive cable. i replaced my positive cable, and so far no engine light, it idles better and doesn't seem to miss (much)
-Nick
Old 10 Apr 2013, 01:58 pm
codes are po300,po304. multiple misfires and misfire cylinder four
Old 10 Apr 2013, 07:27 pm
My advice is to take it to the dealer and ask for a diagnosis only. That way you're not wasting your money replacing parts that don't need to be replaced.
2008 PT Cruiser Touring 135,000 miles
Old 12 Apr 2013, 08:52 pm
Mine is PO302. Flashing at idle then on off idle when driving
Old 12 Apr 2013, 08:54 pm
Im gonna clean the MAP sensor. Or, park it over tall grass after driving it for couple hours
#1 misfire code rocnroller Tech & Performance Forum 1 12 Feb 2013 02:37 pm
code reads po300 echillie1 Tech & Performance Forum 6 03 Mar 2012 07:46 pm
p0304 misfire code sporttraveler Tech & Performance Forum 9 17 Feb 2012 08:26 pm
misfire code at idle specialkay Tech & Performance Forum 4 08 Dec 2011 08:28 pm
ERROR CODE PO335 & PO300 - HELP! PTZIGGY Tech & Performance Forum 7 09 Dec 2009 05:53 pm
