Shaking in idle
Old 12 Apr 2013, 09:46 am
Default Shaking in idle
My 05 shakes sitting in idle with the A/C on, but not with the A/C off. I have already replaced the CMP with a new one from the dealership. Any other ideas on what could be causing this to happen? Thanks.
Old 12 Apr 2013, 09:55 am
Default Re: Shaking in idle
The A/C puts a strain on the engine, the computer is supposed to bump up the idle 100-200 rpm's to help with that, also the radiator fan should come on whenever the compressor is engaged as in A/C or Defrost mode. Is the fan coming on and does the RPM's increase?
Old 12 Apr 2013, 09:58 am
any other symptoms? does the idle get lower? does it run hot?
a little more vibration is normal. the alternator is working harder because the cooling fan is on high and the compressor also puts a little more work on the engine.
Old 16 Apr 2013, 08:04 am
I finally got around to trying to figure out the problem at home. I sat in my driveway with the car on my rpm's where about 800 rpm, then I turned the A/C on max. As the car shook the rpm's went up to 1000 then fell back to 800. I couldn't see whether or not if the fan was coming on by looking at.
Severe shaking at idle invidious Tech & Performance Forum 13 05 Nov 2013 04:30 pm
Shaking PT bluemonster General PT Cruiser Discussions 3 08 Apr 2013 04:39 pm
Shaking like crazy when Idle starts fine omandig Tech & Performance Forum 6 24 May 2012 07:49 pm
Diagnosing sputtering start / shaking while idle q1h Tech & Performance Forum 5 14 May 2012 08:26 pm
Rought Idle and shaking on acceleration dsnowden Tech & Performance Forum 6 08 Sep 2009 09:04 am
