Trans won't shift when hot
Old 12 Apr 2013, 08:25 pm
fezzersc's Avatar
Default Trans won't shift when hot
I have a 2002 PT Cruiser (automatic) and last week when we were driving home it dropped violently into 1st and would not shift. I limped it home at 30 mph.
2 days later I was going to limp it over to my uncle's house, but it shifted fine a drove fine. About 3 miles down the road it dropped down in 1st again and stayed there.
My uncle noticed 2 motor mounts were broke, so we replaced all of them.
Perplexed about the tranny problem. Help me Cruiser gods!
Old 12 Apr 2013, 08:28 pm
Vlefaive's Avatar
Default Re: Trans won't shift when hot
Speaking as a lesser God, I need to ask the obvious..... How's the fluid ? And there's a safe " limp home " feature in most trannies now... Sounds like you need a pro.. spring for the diagnostic... Or where I was raised, my old man made things work with a ball pean hammer .... simpler times
PS: Hey ant Hey ant ! I love it... I had forgotten about that one ... what was the cartoon again ?
'03 GT Blue/ autostick.. 160,000KM ( That's 100,000miles for y'all South of the border ) All the options, the heated leather is a must up here in Canada, Love the solid heavy duty feel and obvious Torque.. The Turbo is strong, fast and reliable.. People that don't understand the love of a PT, probably don't deserve to.
Old 12 Apr 2013, 08:45 pm
fezzersc's Avatar
fluid was fine.
Old 12 Apr 2013, 11:49 pm
fezzersc's Avatar
ant and the aardvark on pink panther
Old 13 Apr 2013, 01:25 am
Drop the tranny pan and see what you've got.
Old 13 Apr 2013, 11:14 am
fezzersc's Avatar
ok, I will check.
Anybody got anything else? There a few topics on this, but no one ever comes back and says what the problem was.
Old 13 Apr 2013, 11:23 am
767skyking's Avatar
Fezzersc...
Had that same problem on my daughter's 02. The transmission computer (located under the front bumper drivers side) was the problem. I have also seen the solenoid and pressure switch assembly cause that problem. Do you get a check engine light?
The "Three Amigos" (And Growing)
Performace, Body and Service, OEM
"Team Amigos FREE Parts!! PM me for details!!
Old 13 Apr 2013, 11:37 am
fezzersc's Avatar
we replaced the TCU on the left wheel well. No go.
Old 13 Apr 2013, 11:43 am
767skyking's Avatar
Might want to pop your connectors off your solenoid and pressure switch and use some dielectric grease. I have seen corrosion problems also cause connection concerns.
Old 13 Apr 2013, 12:09 pm
ROCKETMAN8060's Avatar
Mine did the same thing and it was the pressure switch! Good luck!
ROCKETMAN8060
Manual Trans Stiff Shift? akasurf Tech & Performance Forum 9 02 Sep 2012 01:26 pm
Automatic trans sickspeed shift knob adapter ptcruiseroldschool General PT Cruiser Discussions 2 11 Aug 2012 07:42 pm
Manual trans hard 1-2-1 shift elcam84 Tech & Performance Forum 12 05 Jul 2012 08:05 am
Trans will not shift when hot help!? zarcin88 Tech & Performance Forum 6 07 Apr 2011 10:50 pm
trans shift question 4SPEED General Turbo Discussions 2 07 Nov 2010 06:27 pm
