vibration
Old 13 Apr 2013, 07:30 am
Default vibration
2006 PT Cruiser 2.4l non-turbo. At 55mph get at bouncing affect in front end which begins to lessen at 60mph but does not go away completely. Have replaced the front rotors and pads, and have had the tires balanced. Front end inspection does not reveal any major defects. Boots on drive shafts are intact with no leakage. Any ideas? Thanks, JosephZ
Old 13 Apr 2013, 07:33 am
Default Re: vibration
You had the front tires balanced but did they check for an Out-of-Round tire? Just happened to my wife's Focus. Balanced perfect but second look, they found a uneven round tire.
Old 13 Apr 2013, 07:51 am
Ray_Dockrey's Avatar
^^^^^^Agree. Rotate the fronts to the back and see if the vibration follows.
Old 13 Apr 2013, 07:54 am
The balancing was done at a repair shop and I had informed them of the problem before balancing the tires and they also test drove the car after balancing. Also, before taking the car in to the shop I switched the front and back tires to see if this would help.
Old 13 Apr 2013, 08:13 am
Also, want to add. The shop suggested that the problem 'might be' drive shafts or a motor mount. It's the 'might be' that is a bit discomforting. Thanks, JosephZ
Old 13 Apr 2013, 11:08 am
767skyking's Avatar
How many miles on the Pt? We have had to replace axle shafts at about 130k because of vibration at 55-65 mph
The "Three Amigos" (And Growing)
Performace, Body and Service, OEM
"Team Amigos FREE Parts!! PM me for details!!
Old 13 Apr 2013, 11:31 am
I've been dealing with that problem with my PT for several years now. Starting around 50-55 the whole front end shakes like crazy while i'm accelerating...get to 65 and up, the car is smooth as glass. I've replaced both CV shafts, tie rod ends, control arms, alignment is good, tires are balanced... the only thing that hasn't been replaced on my car are the motor mounts... which will be the next step...when i get some money saved up. I've got a 2006 base 5-speed with 133k on it.
Old 16 Apr 2013, 06:36 am
Thanks for all the input. My 2006 has 99700 miles. When it's all said and done it sounds like it could simply be the motor mounts. I will have them checked. Thanks, JosephZ
Old 16 Apr 2013, 11:51 pm
I have a similar issue with a 2006 touring. 15" tires. 50-55mph only. Tires were rebalanced. No change. I believe it's due to low quality tires. There's a lot of junk coming out of Korea, even with American brand names. Cooper CS4 tires are good in snow, wear well, made in USA, but a little noisy.
Vibration at 70 mph Brunoka Tech & Performance Forum 5 19 Jun 2012 07:36 am
vibration bompa45 General PT Cruiser Discussions 2 24 Jan 2012 01:32 pm
vibration ? 2004PTCruiser Tech & Performance Forum 16 05 Jul 2008 09:40 am
Vibration junkno General PT Cruiser Discussions 15 02 Nov 2004 08:57 am
Vibration!!!! 2003ptcrusierbrusier Tech & Performance Forum 8 05 Jan 2004 08:45 pm
