Valve cover bolt
  • 1 Post By CREWZIN
Old 13 Apr 2013, 02:05 pm
swanjack's Avatar
Default Valve cover bolt
So I went to change my sparkplugs today and found number one and three spark plug threads to be covered in oil. As the electrodes were clean, I assumed that the valve cover gasket (I've suspected a leak there for a while) and the spark plug tube gaskets were to blame. So I decided to take off the valve cover to see what was going on. All but one of the bolts came out without problem, but the remaining one was a bit stiff but nothing of note and when unscrewing it, it sheared, leaving a half inch of broken bolt protruding from the cylinder head
Once I get the remaining bit of bolt out of the head (that's another story), I'll need a new one. But over here in the UK, I've priced up a bolt at the equivalent of $30 , whereas in the US their around $8.
I've established that the bolt is an M6 1.0 6g type, which I think is nothing special. What I'm thinking is if I take the rubber grommet and sleeve off the broken bolt, can I just put these over a normal M6 1.0 bolt ($1) and avoid having to buy one off the dealer? Obviously the new bolt will have to be the same length, or shorter that the old one. Would this be acceptable?
What was intended to be a quick service has turned into a PITA, especially as I dropped a socket down the lower intake manifold, which meant I had to take that off to retrieve it
Thanks for any help.
Old 13 Apr 2013, 02:55 pm
Default Re: Valve cover bolt
The valve cover tightening sequence is in three parts ending in 105 in-lbs. That's not a whole lot so if you get a bolt near enough to what was broken and you can tighten it down so it gets the gaskets tight enough so they won't leak, doing it your way should work. Just my opinion.
rob342 likes this.
spare tire bolt cover? bryman Interior Accessories Forum 3 16 Mar 2012 10:15 pm
Valve Cover VNT General PT Cruiser Discussions 2 30 Jul 2010 07:44 pm
Valve Cover Torque duffner Turbo Performance 19 13 May 2010 09:37 pm
valve cover ? 2 imsopt Tech & Performance Forum 0 28 Dec 2009 07:07 am
EGR valve, 1 bolt?! DIYPTGUY Tech & Performance Forum 4 20 Feb 2009 08:55 pm
