MIL Light
Like Tree2Likes
Old 15 Apr 2013, 10:14 am
Default MIL Light
Help. This is the second time this happens. This morning when I turned on my car the MIL started flashing. Not knowing what to do I turned off the car to take a look at the manual. Anyway, when I turned the car back on all lights turned on as they normally do when you turn on the car. The MIL never turned back on or did it come on while I was driving. Should I still get it checked out? Could something be faulty?
Old 15 Apr 2013, 03:24 pm
Default Re: MIL Light
Reset the computer. Take the negative battery cover off for about 5 minutes. Step on the brake pedal to get rid of any residual static. Put it all back together and run the car, or drive it for a few minutes while the computer re-learns the settings. See if that clears things up.
mrsbarba likes this.
Old 15 Apr 2013, 03:59 pm
Thank you for your reply. I will be doing this ASAP!! THANKS AGAIN!!!
Old 15 Apr 2013, 07:19 pm
rcktpwrd's Avatar
do the key dance to see if there any stored codes first, there might be something starting to go bad...
Joel
2001 PT Cruiser 5-speed; 1976 Oldsmobile Cutlass S; 1990 Chevy 454SS
www.rcktpwrd.com
Old 15 Apr 2013, 10:46 pm
A bit further into this for the newbie :-D
"the key dance".
Take the key, stick it in the ignition.
Turn it from "off"
To "acc"
then back to "off" 3 times quickly.
Then look at the odometer. IF there is and engine trouble code it will show up there :-)
Report back to us gurus what it says for further instruction :-D
rcktpwrd likes this.
Old 16 Apr 2013, 10:45 am
"the key dance".
Turn it from "off"
To "acc"
I will try to do that. The only "testing" I've done is what the manual says to do by turning the key and to acc and checking to see if the light stays lit or starts flashing.....and it stays lit which is supposed to mean everything is okay. But I will try what you've stated and let you guys know. THANK YOU!!!
Old 16 Apr 2013, 10:55 am
Just got back from trying this.....nothing came up...no codes....nothing.
Old 16 Apr 2013, 11:06 am
did it just say "done" if not you need to keep trying. It will always register something. If it registered nothing they key dance wasnt done right :-D
Old 16 Apr 2013, 11:23 am
I tried it 3 times and nothing registered. Guess I'm not doing it right....I'll keep trying it.
Old 16 Apr 2013, 12:14 pm
Try this:
How to retrieve fault codes.
ABS Light, Parking Brake Light, Traction Control Light kupothechocobo General PT Cruiser Discussions 9 28 Feb 2017 01:56 pm
Showing ABS light, Brake light, Traction light on Dash fox50h Tech & Performance Forum 19 18 Feb 2014 11:40 pm
Check engine light: Amber Light: power loss dbleclk Turbo Performance 2 06 Jul 2011 06:12 am
Mork's Tail Light and Reverse Light Tint Progress Morkeste Exterior Accessories Forum 30 23 Jun 2011 12:20 pm
car wont start. car alarm light and airbag light on trigimon Tech & Performance Forum 7 05 Nov 2010 03:42 pm
