Cam Position Sensor Pulling Double Duty?
  • 1 Post By rob342
Old 15 Apr 2013, 04:51 pm
GTCRUISER2006's Avatar
Default Cam Position Sensor Pulling Double Duty?
Hello All,
I have read (in fact, on this board!) that the cam position sensor also doubles as the cam tensioner for our cars (I have a 06' GT Cruiser 5spd.). I have the replacement Mopar sensor ready to be installed. I told the mechanic who is going to install the sensor about the bolt tension needing to be 115 inch pounds. He said "though he has done SEVERAL of this common P/T Cruiser problem cam sensor. He has never heard of it doubling as the tensioner." Can you guru and weekend mechanics confirm this to be the case one last time for me. Maybe, arm me with some solid information so that I can kindly make my point to make sure he does tighten the bolts correctly. Thank you in advance to all.
Bryan
2006 GT Cruiser HO w/ 5spd. Tastes Like Vanilla!
Old 15 Apr 2013, 04:55 pm
Default Re: Cam Position Sensor Pulling Double Duty?
i can verify that your info is incorrect. the sensor is a sensor and the tensioner is a tensioner
the sensor is on the drivers side of the cylinder head, right above the transmission. the timing belt tensioner is on the passenger side of the engine block next to the waterpump
Busted_PT likes this.
Old 15 Apr 2013, 05:03 pm
you also instructed him to over tighten it.
from ALLDATA Pro:
Install camshaft position sensor. Tighten sensor mounting screws to 9 Nm (80 15 in. lbs.) torque.
Old 15 Apr 2013, 05:17 pm
aaah, i see where you read that. someone *cough*CREWZIN must have been having a few cold ones that day.
-just goes to show you can't believe everything you read on the internet.
Old 15 Apr 2013, 10:12 pm
767skyking's Avatar
Ditto! Just a sensor.
The "Three Amigos" (And Growing)
Performace, Body and Service, OEM
"Team Amigos FREE Parts!! PM me for details!!
Old 16 Apr 2013, 01:18 am
Per 2001 factory Chrysler Sebring manual: For 2.4 engine, the torque spec IS 115 in-lbs. [same engine]. Something more interesting is that the torque spec for the magnet behind the sensor is only 30 in-lbs! Overtightening might crack the magnet.
Make sure that the magnet is clean.
I could use a cold one right now. Yaah.
Old 16 Apr 2013, 06:27 am
ok, i went back and looked through the years, from 2001-2006 to make sure im not nuts.
2001-2003 PT had these numbers
2004-2006 PT have these instead
Old 16 Apr 2013, 08:43 am
Glad that was settled. Soon as I saw the first post I grabbed both the Haynes and Chilton manuals to look up the torque settings. They list it as the CMP 115 in-lbs and magnet retaining screw as 32 in-lbs.
Got to admit that I can't see anywhere in those particular manuals that says anything about the sensor being a tensioner but I usually don't put anything down that I haven't read somewhere but was already mentioned ....you can't believe everything you read on the internet.
Old 16 Apr 2013, 09:58 am
Thanks to everyone involved.. glad I didn't argue with the guy! He may now install it freely and I know he knows what he is talking about. Thanks again.
crankshaft position sensor veses knock sensor BeagleDad Tech & Performance Forum 6 13 Feb 2012 06:10 pm
pls help, crank position sensor ilovepts Tech & Performance Forum 1 07 Oct 2011 06:20 am
Throttle position sensor Cruiser73 Tech & Performance Forum 4 23 Mar 2011 12:09 pm
Cam Shaft Position Sensor Johns Steel Blue Tech & Performance Forum 9 15 Apr 2008 07:38 pm
cam position sensor 4SPEED Tech & Performance Forum 1 25 Sep 2006 04:16 pm
