No power when starting the car
Old 16 Apr 2013, 12:24 pm
Default No power when starting the car
I have a 05 manual, when I put the key in the ignition and turn the key I lose power (everything turns off) its like it has no battery. The radio does not work, lights etc the battery is 4 months old, I thought it was the electrical ignitions switch so I changed it but still have the same problem. Any suggestions?
Old 16 Apr 2013, 02:22 pm
Ray_Dockrey's Avatar
Default Re: No power when starting the car
Is the battery charged? Something could have been left on or if you have fog lights they may be stuck on and ran the battery down. Also could be that the battery went bad. They do that sometimes. Check the cables too. They are a known source of issues too.
Old 16 Apr 2013, 02:50 pm
I tested the battery battery is good I use this to commute everyday.it has no fog lights I checked everything if I left anything on everything is off, before the problem, when I got in the car everything was working but as soon as I turn the key everything shut down.
Old 16 Apr 2013, 02:58 pm
How did you test the battery? There may be enough juice to run some things but not enough amperage to turn it over.
Old 16 Apr 2013, 03:44 pm
I tested with a battery tester. The car does not crank nore the head lights are deam, the dase light don't even turn on! I tried turning on the hazard lights on and I just heard a buzzing noise. Is there a main fuse that control the electrics that I can test?
Old 16 Apr 2013, 04:24 pm
cruserdad1976's Avatar
did you try to jump it??? I knwo the battey says its fully charghed but try a jump its free and if it works it has to have something to do with the battery
Old 16 Apr 2013, 04:43 pm
Yes I did nothing happen!
Old 16 Apr 2013, 05:37 pm
check the start wires OR does the car have a netural saftey switch
Old 16 Apr 2013, 06:22 pm
I don't think it has a netural safty switch its manuel
Old 16 Apr 2013, 08:27 pm
even maual transmissions have a safety switch, probably behind the clutch pedal.
2016 Kia Soul Plus Black
2006 PT Cruiser no power to power seat paradyne64 General PT Cruiser Discussions 5 29 Dec 2016 02:54 am
Power Steering-it takes power just to steer it 05PTGT General Turbo Discussions 8 29 Jan 2013 08:37 pm
How to: Get power to radio and add circuits for power xwing777 Sound and Security Forum 19 10 Jun 2012 04:49 pm
FIXED: No power to power sockets, front or rear InTheBlack Tech & Performance Forum 2 11 Jan 2011 11:12 pm
Erratic starting and power locks chatter cruisinglite Tech & Performance Forum 27 21 Oct 2009 06:43 am
