Blinking Check Engine Light, New and Can't Be Good
Old 16 Apr 2013, 01:32 pm
GTCRUISER2006's Avatar
Default Blinking Check Engine Light, New and Can't Be Good
Hello All,
I don't know if this ties in or not. I'm about to have the CPS on my 06' GT 5spd. changed (Mopar part came today, in fact). It's been working/not working for months. Unfortunately, though right now it's in a working phase with no check engine light on and no limp mode. As I was driving home from dropping the wife off at the train station. The car started sputtering and running rough (though, it did not die) and the check engine light came on BLINKING. A few seconds later the car was running fine again and the light was gone.... Help? Any main problems or common issues on this one? Why do I feel like I'm heading for trouble fast? Any thoughts from you guru and weekend mechanics would be greatly appreciated. Thanks in advance.
Bryan
2006 GT Cruiser HO w/ 5spd. Tastes Like Vanilla!
Old 16 Apr 2013, 02:19 pm
Ray_Dockrey's Avatar
Default Re: Blinking Check Engine Light, New and Can't Be Good
It could be the sensor but I would also check all the wiring to make sure it isn't shorting out somewhere causing intermittent issues.
Old 16 Apr 2013, 03:26 pm
Could be the wiring to/from the sensor. My wiring harness around the back of the engine came in contact with the half shaft and burned through till the wires split apart. Get the sensor changed and check the harness as far as you can for any damage.
2004 Engine misfire and flashing check engine light fg1911a1 General Turbo Discussions 15 26 Jul 2014 06:20 pm
check engine light is on running good partyd General Turbo Discussions 11 15 Feb 2012 08:23 pm
Check engine light and battery light on tay2208 Tech & Performance Forum 2 27 Jul 2011 05:44 am
Dashboard goes crazy, check engine light,oil light...... jggarza3247 Tech & Performance Forum 2 10 Jul 2011 06:23 am
Check engine light: Amber Light: power loss dbleclk Turbo Performance 2 06 Jul 2011 06:12 am
