2006 PT Follow-up headlight question
Old 17 Apr 2013, 01:24 am
Default 2006 PT Follow-up headlight question
I have a 2006 PT non turbo and the driver side low beam is currently not working, but the high beam does. I have gotten the light to work for a bit by taking the bulb out of the housing and messing with the bulb and wires. Is it possible that the computer still needs to be reset to permanently fix this problem? I was thinking that maybe one of the "tabs" inside the plug might have come loose from the wiring. Any advice would be most helpful. Thanks.
Old 17 Apr 2013, 06:10 am
Thejman3's Avatar
Default Re: 2006 PT Follow-up headlight question
Sounds to me the bulb Is old and needs replaced, it could be a short in the wire but I would bet the bulb is on its way out. when bulbs get old sometimes the filament inside will move around and make contact and work sometimes and other times won't. You could test by taking the other side out and plugging it in to see if it works like it supposed to.
Old 17 Apr 2013, 06:16 am
Ray_Dockrey's Avatar
I agree. If messing with bulb and wiring will get it to work sometimes then it's either a bad bulb or in the plug/wiring. If it was the TIPM it wouldn't come on at all.
Old 28 May 2013, 07:18 pm
Exclamation Re: 2006 PT Follow-up headlight question
I got side swiped and my fender was messed up so I bought a new one. The crash broke three of the four pieces that mount the headlight to the car and it also bent where it mounts. I got a new fender to only find out that the part that is bent doesn't come with it. Where can I buy a new mount or can I just bend it back into place?
Old 28 May 2013, 07:28 pm
Seth,
I looked up the headlights in the 2006 Parts Catalog and the pieces that your talking about don't seem to be mentioned. You might have to visit a salvage yard to see if those parts are available.
2006 Headlight Fuse Location aea_1962 PT Cruiser News and Rumors 14 12 Dec 2013 09:36 am
Xpel Headlight Protection Kit - clear NIB 2006 up GremlinGal Classifieds: For Sale/Trade 5 09 Aug 2012 05:53 am
2006 no turn signal or headlight havensole Tech & Performance Forum 13 18 Jun 2011 08:13 pm
2006 and up headlight trim SCBluePT Exterior Accessories Forum 3 29 Nov 2010 11:31 pm
Follow Up on A/C problems FSUCPA General PT Cruiser Discussions 6 27 Jul 2009 05:31 pm
