Help needed with vibration
Old 17 Apr 2013, 07:56 am
Default Help needed with vibration
I have a 2004 2.2 diesel 5 speed manual which has a vibration under acceleration which sounds like the exhaust is touching the body or subframe but it's not,I have checked the motor mounts and they are good with no splits,the noise comes sort of in three times in every gear change if driven a little hard.The harder you drive it the louder it gets,so if I drive slow you can still hear it but quieter,the wheel bearings are good,no noise or rouighness when spun or driven in the air on a lift.I have even put the E brake on and rocked the car with the engine running in 1st gear to rock the engine but it doesn't make that noise,it's only under hard accleration,any idea's as I've tried everything,thanks
Old 17 Apr 2013, 10:51 am
Default Re: Help needed with vibration
Sounds like you're describing a noise rather than a vibration.
Check the heat shields for looseness - they can set up a buzz...
Old 17 Apr 2013, 10:59 am
Thanks but it's not the heatshield as it doesn't have one,it's a noise and a vibration and the exhaust is nowhere near anything to rub against even though you'd swear it was the exhaust rubbing on something
Old 20 Apr 2013, 03:38 am
Well I got a friend who has an identical car and he's going to let me swap bits to eliminate the noise
Old 22 Apr 2013, 02:56 am
Just tried something,don't know why I tried it but it doesn't make the noise if you go fast in reverse?? Any ideas??
vibration JosephZ Tech & Performance Forum 8 16 Apr 2013 11:51 pm
Vibration at 70 mph Brunoka Tech & Performance Forum 5 19 Jun 2012 07:36 am
vibration bompa45 General PT Cruiser Discussions 2 24 Jan 2012 01:32 pm
Vibration between 40 & 60 mph???? anyone had this? gtbright General Turbo Discussions 10 16 Jul 2005 03:06 pm
Vibration!!!! 2003ptcrusierbrusier Tech & Performance Forum 8 05 Jan 2004 08:45 pm
