Starts runs 20 mins then dies please help
Like Tree3Likes
Old 18 Apr 2013, 03:19 pm
Question Starts runs 20 mins then dies please help
I have a 2001 pt cruiser limited it starts fine runs for 20 minutes then dies have to wait 2 mins then starts back up and runs for 3 mins then dies. I have replaced the camshaft sensor and fuel pump. so confused as to what it is if you can help that would be most appreciated
Old 18 Apr 2013, 03:29 pm
Default Re: Starts runs 20 mins then dies please help
check the wiring loom that goes to the alternator and crankshaft sensor. on the 2001 it'll occassionally hang down and rub on the passenger side driveshaft, chafing it to the point of exposing wires.
2016 Kia Soul Plus Black
Old 18 Apr 2013, 04:00 pm
I agree with the above but also use the link below to see if there's any stored fault codes in the computer.
How to retrieve fault codes.
Old 18 Apr 2013, 04:17 pm
does it start running rough before it dies? if it does, the ignition coil would be my guess.
i've fixed a buick, a pontiac, an acura, and a prelude, all with failing coils. when they start to fail, they quit working when they get hot. as soon as they start to cool, they start working again, since 2 minutes only lets it cool a little bit, it only runs for a little bit. this would explain why it runs for a little after you let it cool a little.
the good thing about all those cars, is you can check the problem by putting a bag of ice on coil and see if the problem goes away. unfortunately it's under the intake on these cars. when my prelude did this to me and i made it home by buying a bag of ice and some ziplock baggies from a gas station. then i got a coat hanger from the dry cleaners next door. i iced the coil and made it home with no problems.
i'm a sign painter, NOT a mechanic. -but it's something to consider.
Carl48 likes this.
Old 18 Apr 2013, 04:43 pm
checked and it has a tiny spot of bare wire close to alternator were it has rubbed
Old 18 Apr 2013, 04:44 pm
reading done on the codes thats all
Old 18 Apr 2013, 04:51 pm
OK, "done" says there's no fault codes stored in the computer.
Old 18 Apr 2013, 05:04 pm
Old 18 Apr 2013, 05:09 pm
yup, that's what mine looked like. skin back some more of the plastic coating and see if more wires are damaged.
Old 18 Apr 2013, 05:11 pm
did not see any others do i have to buy a new one or will electrical tape work?
starts and then dies on me Harvey1986 Tech & Performance Forum 8 17 May 2017 04:50 pm
Starts and stops again? daggie Tech & Performance Forum 10 20 Oct 2012 08:33 am
PT starts bad ProDigit General PT Cruiser Discussions 5 03 Nov 2010 02:23 pm
2001 PT - Starts, runs, stalls...won't start silver7 Tech & Performance Forum 12 20 Sep 2010 03:11 pm
The Pt starts hard LNBNDN General PT Cruiser Discussions 1 03 Jun 2010 08:14 am
