engine swap
Like Tree5Likes
  • 1 Post By Busa_Powered
  • 1 Post By 767skyking
  • 2 Post By Busted_PT
  • 1 Post By pt06
Old 18 Apr 2013, 07:01 pm
Default engine swap
Hey guys. My 02 PT needs another motor. I just found another one at a junkyard with 89,000 miles. I plan on taking it to a trusted mechanic to have the swap done. I want to try and take everything he will need to do the job. Aside from the regular fluids and tune up the motor will need, I plan on having a timing belt, tensioners, water pump, and exhaust gaskets. What other things will I need to bring for him to have everything he needs for the swap, or is this all? Most of the old parts on my motor like hoses and belts are all barely new, so I've got that covered too. Thanks, and any advice is appreciated.
Old 18 Apr 2013, 07:29 pm
Default Re: engine swap
You dropping in a hemi?
Hokie_Phd likes this.
Old 18 Apr 2013, 08:31 pm
That would be nice
Old 18 Apr 2013, 09:08 pm
767skyking's Avatar
Jon...
If it was my swap, I would replace the front and rear main seal. You would be very frustrated if a leak happened to show up between the engine and transmission.
Busted_PT likes this.
The "Three Amigos" (And Growing)
Performace, Body and Service, OEM
"Team Amigos FREE Parts!! PM me for details!!
Old 18 Apr 2013, 09:18 pm
One thing I can think of is making sure that the replacement engine is compatible. The crank sensor has to be on the same side as the one in it. Just a thought.
Old 19 Apr 2013, 06:14 am
Ok, thanks so far guys I'm going to check with the junk yard about the crank sensor,,, mine is on the passenger side. If its not on the passenger side, like mine, then it wont work? Can I make it work, if its on the opposite side as mine?
Old 19 Apr 2013, 07:01 am
It's got to do with the computer reading the timing. To my knowledge, no.
Old 20 Apr 2013, 03:42 am
I'd add: cam seals and oil sending unit. Also, check on this site for more info on the crank sensor/computer issue. But I believe Busted is correct.
767skyking likes this.
Old 20 Apr 2013, 01:24 pm
I would also suggest plugs, wires, grommits, valve cover gasket and manifold seals :-D 89k could have been well taken care of, or not, however these things are just things i would have done IMO
Old 20 Apr 2013, 01:36 pm
Ditto on the seals and oil sending unit.
2.4 engine swap krozby Tech & Performance Forum 15 11 Feb 2016 09:31 pm
Can I swap a 2001 w/egr engine for a 2002 engine w/o egr? cas0918 General PT Cruiser Discussions 5 15 Feb 2013 11:58 pm
engine oil pan swap cruizinla Tech & Performance Forum 2 13 Oct 2009 07:32 am
02-03 Engine swap brit Tech & Performance Forum 0 13 Apr 2009 12:49 am
engine swap INFERNODPPT Tech & Performance Forum 21 29 Oct 2005 10:00 pm
