Need help to swap to a manual transmission
Old 19 Apr 2013, 12:58 pm
Default Need help to swap to a manual transmission
I need help with doing a manual tranny swap on mu pt cruiser turbo I would like to know everything I need to do the swap
Old 19 Apr 2013, 02:05 pm
UptownSport's Avatar
Default Re: Need help to swap to a manual transmission
Theres tons of swap info at neons.org
www.neons.org • View topic - How-To: 5 speed swap (2gen), ATX to MTX
note that all n/a transmissions interchange, you can swap bellhousings cable to hydraulic.
Old 19 Apr 2013, 02:46 pm
cruserdad1976's Avatar
LOTS of TIME Patience and probela some greenbacks will eba good start
Old 19 Apr 2013, 05:01 pm
Guys do Neon swaps literally for a few hundred $.
Neons use same/similar parts, but theres a HUGE informal supply network
The 'new' stuff you need to buy (clutch) is expensive
Old 19 Apr 2013, 06:10 pm
what would be a better tans for it from the gt or neon one
Old 20 Apr 2013, 12:43 am
Ooops! Didn't see it was a turbo!
Good luck!
Old 21 Apr 2013, 02:33 pm
what would be the best route to manual on the pt turbo
Old 22 Apr 2013, 11:36 am
767skyking's Avatar
Hey Cheeskake...
If you need a "Getrag" shifter setup, I have an extra one!
The "Three Amigos" (And Growing)
Performace, Body and Service, OEM
"Team Amigos FREE Parts!! PM me for details!!
Old 22 Apr 2013, 07:34 pm
Smile Re: Need help to swap to a manual transmission
Hi, I'm not sure exactly how you'd do the install but I do know most of the stuff you'll need. The easiest way to go is to get the "getrag" transmission from a GT cruiser or an srt4 neon it's the same tranny used in both, you'll obviously need clutch pedal, wiring, etc and most importantly you'll need a new PCM one from a manual PT GT and then have it flashed to your vin. If you use your current PCM it won't work with the manual trans. That's all I kno so far hope it helps.
Purple 2005 PT GT ATX w/ Mopar stage 1 PCM, Diablosport 93 oct tune, airbox mod, K&N drop in filter, Mopar BOV, AGP wastegate (8 psi spring), Custom made stage 1 camshafts, motor mount inserts, NGK Iridium plugs, MSD wires, ARP Head Studs, Gates Racing Timing Belt, AC Delete kit, purple painted Valve cover, Rebuilt (stock) Turbo , AEM Boost, Oil Pressure, and Wideband guages, triple guage A pillar pod, Strut Tower brace, Needswings 3in o2 housing, 3in downpipe w/ high flow cat and electric cutout, 2.5in Magnaflow catback, custom check valve, custom larger capacity trans cooler w/ built in cooling fan, Eibachs pro lowering springs, KYP front and rear struts, matte black hood and grille, gloss black stock SRT neon rims, purple lug nuts, blacked out tailights and reflectors so far. Built and bored out motor, AGP S256 turbo, ported cylinder head, and built trans soon to come.
Old 22 Apr 2013, 08:57 pm
needmoretoys's Avatar
Are you sure about that? I read before that the Srt trans is a little longer.
Lenny
FEBRUARY CRUISER OF THE MONTH
what is wrong with my manual transmission? BrianW General PT Cruiser Discussions 52 20 Jun 2016 10:27 pm
Manual transmission htway750 General PT Cruiser Discussions 6 13 Aug 2012 09:47 am
Manual Transmission justn0w General PT Cruiser Discussions 4 18 Oct 2011 11:10 pm
Manual transmission 1gr8rubaz Tech & Performance Forum 0 05 Oct 2007 11:22 am
Manual Transmission Parts? where to buy... runtime Tech & Performance Forum 3 26 Apr 2007 07:24 pm
