2002 pt cruiser rough idle when cold and 0303 code
Old 19 Apr 2013, 04:25 pm
Default 2002 pt cruiser rough idle when cold and 0303 code
I have a 2002 pt cruiser that I have just replaced the engine in. I has a very rough idle when it starts up cold just like it wants to stall. Once the temperature comes up it runs and idles just fine for the most part. I thought it may be the EGR valve so it removed the EGR tube from the intake and plugged the hole in the intake. It seemed to start good cold so I replaced the EGR Valve with a new one but as soon as I put the EGR tube back into the intake the problem came back.
I don't know where to go next.
Any help appreciated.
Old 20 Apr 2013, 03:28 am
Default Re: 2002 pt cruiser rough idle when cold and 0303 code
Check the EGR vacuum lines for proper routing. There is a diagram under the hood? Check pcv valve and its hose.
Old 23 Apr 2013, 08:31 am
Well, 303 is cylinder 3 missfire - when were plugs and wires last done? What gap was used? (Should be 0.040)
If plugs/wires are good, spray starting fluid along seams of intake manifold - if idle smooths out, you need to replace intake gasket.
Old 29 Apr 2013, 05:54 pm
Have just replaced the plugs and wires and yes gapped to .40 have some further info have checked all vaccuum lines and the routed good and no cracks or leaks. I knwo have a code 0401 coming up which is egr exhaust gas recirculation flow insufficient detected. Have checked and clecned egr valve no change am considering changing the egr transducer to see what happens.
Let me know iof this is a good place to go.
here is my scan tool report data
Report#: 1
Report Date: 4-29-2013 (6:21 PM)
Vehicle Year: 2002
Vehicle Make: Chrysler
Vehicle Model: pt cruiser
Vehicle Engine Size: 2.4l
Vehicle VIN: 3C4FY48B02T227341
Vehicle License Plate: ABCD123
Vehicle Mileage: 200000
Stored:
P0401 Exhaust Gas Recirculation Flow Insufficient Detected
P0303 Cylinder 3 Misfire Detected
MIL ON
MisFire Monitor Complete
Fuel System Monitor Complete
Comprehensive Component Monitor Complete
Catalyst Monitor Complete
Heated Catalyst Monitor Not Supported
Evaporative System Monitor Not Complete
Secondary Air System Monitor Not Supported
A/C System Refrigerant Monitor Not Supported
Oxygen Sensor Monitor Complete
Oxygen Sensor Heater Monitor Complete
EGR System Monitor Complete
DTC for which Freeze Frame was Stored P0303
Fuel System 1 Status Closed Loop
Fuel System 2 Status Not Supported
Calculated LOAD Value 5.88 %
Engine Coolant Temp 71.60 F
Short Term Fuel Trim - Bank 1 -14.84 %
Long Term Fuel Trim - Bank 1 10.94 %
Intake Manifold Absolute Pressure 15.65 inHg
Engine RPM 800 rpm
Vehicle Speed Sensor 0.00 mph
any help appreciated
Old 29 Apr 2013, 11:49 pm
First cars ran without EGRs, then they added EGRs with vacuum transducers [whatever they are], now we have computers controlling transducers controlling EGR valves. How sweet!!!
This may be as simple as a bad wire/connection between the computer and the EGR, or a plugged/defective EGR valve. Or not.
Old 18 May 2013, 03:30 pm
So an update to what was going on I now an 0401 code as well as 0303 I know 0401 is EGR insufficient flow have tried changing EGR's as well as transducer and when I accelerate hard it stumbles and won't even pick up until I let off the gas and accelerate moderately.
Old 14 Jun 2013, 04:46 pm
So update to this situation. The 0303 code is gone but the 0401 code remains. Have cleared codes and just keeps coming back. I have manually pushed the EGR valve open while it was running and the car stumbled and almost stalled. This tells me the passages are open. Checked vacuum at the throttle body and lots of vacuum. Is there any way to test the vacuum coming from the transducer to the valve. What is the purpose of the backpressure hose coming from the bottom of the egr to the transducer.
Old 15 Jun 2013, 02:59 am
gordon; I only have info from a 2001 sebring. It says there is a 20 amp fuse inside the PCM for the egr valve.
The backpressure hose sends a 'signal' to the transducer which controls the EGR valve. It may be sold only as a complete unit.
Keep us informed.
Rough idle and code 1193 NSC808 Tech & Performance Forum 12 06 Sep 2012 05:40 pm
2002 rough idle only when in gear after sometime J5BAIL Tech & Performance Forum 7 23 Apr 2012 11:04 am
01 2>4L rough idle when warm w/p1193 code pthead Tech & Performance Forum 0 25 Mar 2012 06:22 pm
2002 PT Cruiser Rough Idle Kirby1 Tech & Performance Forum 4 13 Jun 2010 10:04 pm
Code 0303 # 3 cylinder misfire Bob0815 Tech & Performance Forum 4 17 Sep 2009 08:21 pm
