Changed spark plug/wires on 2004 pt...with pics
  • 1 Post By shelbyzman
Old 20 Apr 2013, 11:50 am
shelbyzman's Avatar
Default Changed spark plug/wires on 2004 pt...with pics
I just got done changing the spark plugs and wires. The guide in the stickies for changing spark plugs was very helpful but I was able to do it in less steps on my pt. First I undid the air filter hose...then took off the bolt front the bracket that is back next to the radiator fluid canister (bolt pic attached). Then took off the five bolts holding the intake manifold off. I used a bungee cord to hold it up on the hood release (as the guide on here said to do). I used a old shirt to put over the manifold openings so nothing fell in. Then I changed the plugs and wires one by one. I ran into an issue with my sockets coming apart when I tried to remove the socket after tightening, so I took some duct tape to keep the socket and extensions from coming apart. This worked pretty good....I regularly use duct tape with my jobs...
Hope these are some helpful tips
neverwillbe likes this.
2007 PT Cruiser GT 5-speed 17x8 Konig Inception wheels K&N style intake auto throttle body Spec D tail lights Blow off plate 10.2mm plug wires Cat-Back "DNA Motoring" exhaust w/ Thrush glasspack "blacked out" DIY ground effects added boost gauge (in place of analog clock)
Old 20 Apr 2013, 12:44 pm
Default Re: Changed spark plug/wires on 2004 pt...with pics
Hard to see but it looks like you over did it with the duct tape.
Old 20 Apr 2013, 06:24 pm
shelbyzman's Avatar
Well, because I had a socket, extension & adapter....I "needed" to use alot of duct tape
MSD 8.5 spark plug wires wwpptc Classifieds: For Sale/Trade 6 30 Apr 2012 12:51 pm
B&B Spark Plug Wires WolfmanG Tech & Performance Forum 2 19 Dec 2010 02:15 am
just changed spark plugs with BWD wires edb Tech & Performance Forum 6 13 Sep 2010 01:46 am
Spark pulgs and spark plug wires? balvarez814 Tech & Performance Forum 1 13 Aug 2008 08:16 pm
new spark plug wires gottago Tech & Performance Forum 22 30 Oct 2004 02:26 pm
