speedo change- kms. to miles
Old 20 Apr 2013, 10:29 pm
Default speedo change- kms. to miles
hi i have a Canadian 2005 base pt 5 speed with the speedometer and odometer in kms. can i change the variable speed sensor (v.s.s.) and instrument cluster with a U.S. 5 speed to give me miles instead of kms? di i have ti change the p.c.m. also? any info would be appreciated. thanks jim hoysa
Old 21 Apr 2013, 07:53 am
Default Re: speedo change- kms. to miles
I did a fast search and what it looks like is a replacement of the instrument cluster is needed. In 2006 and above, the PT came with a "Personal Settings" button that would allow you to go back and forth but the first generation (01-05) doesn't have that choice.
Old 21 Apr 2013, 09:32 pm
thank you. i will get an instrument cluster from another 2005 at a u-pick . should the v.s.s. have to changed too? jim hoysa
Old 21 Apr 2013, 09:50 pm
Wait a sec. The new cluster is what I found in a search. That should be verified somehow before laying out any money for a new cluster. Not sure about the V.S.S.
Old 22 Apr 2013, 09:21 am
2step's Avatar
What's being suggested is a "new" US spec cluster face. The electronics/mechanics/needles remain the same. It's just the graphics that are changed so although the needle will point to the same spot, the numbers are shifted to indicate miles instead of kilometers. It's a small project that will only take a couple hours.
I believe on the non turbo, the needle is straight up at 60mph and on the turbos is straight up at 70mph. If that doesn't correlate to how the Canadian speedo reads then I might not be 100% accurate with my info.
Old 22 Apr 2013, 11:38 am
767skyking's Avatar
Hey Jim...
Did you leave California yet? I do have some clusters. I can hand one to you if you are still here.
The "Three Amigos" (And Growing)
Performace, Body and Service, OEM
"Team Amigos FREE Parts!! PM me for details!!
PT speedo not working paul25 Tech & Performance Forum 3 11 May 2013 12:40 am
speedo issue paddywagon General Turbo Discussions 4 15 Dec 2011 09:47 pm
RED LIGHT IN SPEEDO?? drumrooster Tech & Performance Forum 1 20 Jul 2011 08:17 am
120/140 speedo no abs desig in vin ?? calhbkid General PT Cruiser Discussions 7 14 Mar 2010 01:43 pm
speedo change 4SPEED General PT Cruiser Discussions 3 26 Sep 2006 07:49 pm
