HELP ME! NO POWER TO ANYTHING!!
Old 21 Apr 2013, 03:39 am
Default HELP ME! NO POWER TO ANYTHING!!
i have a limited edition 2002 pt cruiser. my battery moved when i was stopping and the positive terminal touched the frame of the car and everything went dead. all fuses (engine bay and under dash) are fine visually. inspected all of them pulled them all out. disconnected all battery terminals (positive/negative) cleaned terminals and where the wires were grounded. nothing is working at all. no lights, i mean really no power to anything, doesn't crank no power. tried jumping it still nothing. took battery to auto zone and they say its 100%. I NEED ALL YOUR HELP PLEASE!! THANK YOU!!
Old 21 Apr 2013, 07:38 am
Default Re: HELP ME! NO POWER TO ANYTHING!!
Do the lights turn on? Dome light come on when you open the door? If not, trace/replace the battery cables because if your battery is good, all fuses are good, the battery power isn't getting to where it needs to go. You need to get/buy a voltage tester to see where the battery power is getting to. You only visually tested all the fuses, now find out if power is getting to the box itself. Double check fuse #13 in the PDC (Power Distribution Center) which is another name for the fuse box in the engine compartment. You did check all the fuses in the PDC as well as the interior fuse box, right?
Old 21 Apr 2013, 05:01 pm
no lights come on at all. no power to anything. i tested the battery cables with a fluke. and they are still fine. i also tested the pdc with the fluke and its fine there too. but i tried it in the cigarette lighter in the car and dont get anything. im really stumped on this electrical issue cause there are so many possibilities. i just hope that my ecu isnt fried! even if it was shouldnt i still have power to atleast the light in the car?
Old 21 Apr 2013, 05:05 pm
Yes, you'd think there would still be power to the accessories even if the computer was bad.
Old 21 Apr 2013, 05:19 pm
so where do i go from here? do you think the pdc could have been fried without all the fuses blowing? all suggestions would be looked into.
Old 21 Apr 2013, 05:44 pm
According to the chart for the 2001, there's two grounding wires from the battery. Make sure they aren't fried and that the battery has a good ground.
Carl48 likes this.
Old 21 Apr 2013, 06:30 pm
When the positive terminal touched the frame, the return path was through the grounds...check the ground conductors and connections per Crewzins advice.
Old 21 Apr 2013, 06:51 pm
would this be for the 2002 model also limited edition? looks different
Old 21 Apr 2013, 07:00 pm
The chart was taken from the Haynes/Chilton manual which covered the 2001 thru 2003 models. Doesn't matter what EDITION. They are all the same. A couple small changes like the EGR system in the 2003 but that doesn't matter in your situation.
Old 22 Apr 2013, 02:03 pm
Should there be a complete current when with a fluke connect positive and ground battery cable without battery in it?
2006 PT Cruiser no power to power seat paradyne64 General PT Cruiser Discussions 5 29 Dec 2016 02:54 am
Power Steering-it takes power just to steer it 05PTGT General Turbo Discussions 8 29 Jan 2013 08:37 pm
How to: Get power to radio and add circuits for power xwing777 Sound and Security Forum 19 10 Jun 2012 04:49 pm
Power?? jakeiniowa Stage Turbo Kits 15 08 Nov 2011 09:59 am
FIXED: No power to power sockets, front or rear InTheBlack Tech & Performance Forum 2 11 Jan 2011 11:12 pm
