Ceramic pads
Old 22 Apr 2013, 12:10 am
Vlefaive's Avatar
Default Ceramic pads
Anyone have a strong opinion for or against ? I'm swapping out the rotors too, if it's not obvious, any thoughts on getting the best rotors avail ? I'm usually a pretty gentle driver, but appreciate quality if there's actually any true difference..... thanks .... My daughter's now driving, and it seems to me she prefers to rub the curb to slow down ..maybe new brakes will encourage her to use them instead ....LOL
'03 GT Blue/ autostick.. 160,000KM ( That's 100,000miles for y'all South of the border ) All the options, the heated leather is a must up here in Canada, Love the solid heavy duty feel and obvious Torque.. The Turbo is strong, fast and reliable.. People that don't understand the love of a PT, probably don't deserve to.
Old 22 Apr 2013, 12:15 am
Default Re: Ceramic pads
Ceramics certainly stop quicker, and last longer. However if your using them for performance applications, the issue they have is they HEAT UP and i mean HEAT UP...to the point of glowing. your rotors will glow too :-D
With that said....they last MUCH longer and give you 3x better stopping power.
Also ceramic pads are noisy. Ya know the pad warning indicators that make that squealing sound? A lot of ceramics make that the day you put them in, unless you put in ceramic rotors too.
With pads that heat up so much i suggest vented rotors.
I have these on my car and while pricey as hell, they WORK :-D
http://thmotorsports.com/i-157240.as...FYtDMgodTysAIw
Old 22 Apr 2013, 04:09 am
Vlefaive's Avatar
Many thanks... food for thought
Old 22 Apr 2013, 07:32 am
I have used and drove many different makes of cars with ceramic brakes without any noise on regular rotors. Not all are as clean as they say they are. If you drive hard enough to glow a rotor, you will know because you will need to turn it for warped rotor shake. Many OEM are ceramics.
Old 22 Apr 2013, 11:28 am
767skyking's Avatar
A local auto parts shop in the IE has slotted and drilled rotors. He has his own CNC machine and does the work for many dealers and garages in the area. At one time, he would also offer nickle plating as as option. I use them with ceramics and have had great success on my Pt's and Lexus's. Here is a picture of the fronts for my Lexus (nickle plated). He is very reasonable and will ship. If interested, PM me and I will forward his number. He usually charges $125 for a pair.
The "Three Amigos" (And Growing)
Performace, Body and Service, OEM
"Team Amigos FREE Parts!! PM me for details!!
Old 22 Apr 2013, 01:14 pm
Vlefaive's Avatar
Thanks a million skywing, I'l let you know
Old 22 Apr 2013, 01:15 pm
True, however if you brake hard from 70mph to 0 with ceramic pads + ceramic rotor........they will glow :-D I've done it haha.
Mercedes had to put in cooling vents to prevent this because it was starting tire fires in the early 2000 models :-)
Old 22 Apr 2013, 02:23 pm
767skyking's Avatar
I just confirmed with Andy at "Riverside Auto" for prices...
drilled, slotted
Non turbo - $90, fronts
Turbo - $140, ALL FOUR!
Old 22 Apr 2013, 04:21 pm
drilled, slotted
Cool trick i realized when i did my control arms and also my rotors.
The turbo vs non turbo parts. Unless they have to do with electrical, the engine or the tranny.
They will mount to the non turbo no problem :-)
My rotors are for a turbo, so are my painted calipers and entire suspension -D
If you own a non turbo, buy the turbo rotors, its the same thing :-D
Old 22 Apr 2013, 07:23 pm
drilled, slotted
DEPENDS 100% ON THE FINISH OF THE ROTORS!
I've seen drilled, slotted, vented, double-cut rotors all over the place for anything from $125 to $400 for all four. Now I'd probably say that $140 for all four is a good price IF YOU'RE NOT A DRIVER LIKE ME!
That means, I run up and down mountain roads, through all kinds of "roller coaster" roads up and down all of the East Coast, including the Tail of the Dragon at least four times a year. Along with this, I tend to drive like a total Chromenutcase idiot sometimes. I'm still on factory rotors and pads and they are shot, I mean totally shot. When I get them wet, I just about scare the pee out of myself if I have to hit the brakes suddenly, because they'll go to the floor and not hardly slow my PT down.
So, if you are a hard driver, and like running curvy roads, you'd better get drilled/slotted rotors that are excellent in size, and must be zinc coated thick enough to last at least 100k miles. Now we have a member here, Adam, who runs ThatRotorShop, and you can see some of his items here on this post: Group buy Rotors/Pads/SS lines
767skyking likes this.
Ceramic Pads = New Rotors? gvbeta Wheels, Tires, Suspension 9 07 May 2009 12:14 pm
Best Ceramic Brake Pads onefastcruiser General Turbo Discussions 18 25 Mar 2009 07:17 pm
Morse ceramic pads? Hill Cruiser General PT Cruiser Discussions 7 15 Aug 2005 04:44 pm
Akebono Ceramic Pads for 03 GT mangusta1969 Turbo Wheels/Suspension/Handling 11 03 Oct 2004 06:04 pm
Ceramic Brake pads? PT-GTA Turbo Wheels/Suspension/Handling 18 13 Feb 2004 05:30 pm
