Computer rest without disconnecting the battery?
Old 22 Apr 2013, 08:27 pm
needmoretoys's Avatar
Question Computer rest without disconnecting the battery?
Is there a fuse that I can take out insted of disconnecting the battery to reset the computer? If so can someone tell me which one. I haven't pulled the cover under the hood yet I will look at that tomorrow. There should be an ECM fuse someplace right?
Lenny
FEBRUARY CRUISER OF THE MONTH
Old 22 Apr 2013, 08:40 pm
Default Re: Computer rest without disconnecting the battery?
Lenny, I'm sure Crewzin will comment on this, as I'm not all that familiar with electrical on pre-2006 models, but I believe the IOD fuse may be the one you're talking about. Someone I'm sure will comment on that.
Old 22 Apr 2013, 08:55 pm
Thanks. I guess I should have said it was an 03. I was thinking that was the fuse but I also think that one would cause me to lose any radio presets. I'm not sure. If that is what it has to be then I would do it. not big deal either way.
Lenny
Old 22 Apr 2013, 09:52 pm
I can't answer your question. It's easy enough to pull the negative cable so I've never looked into pulling one of the fuses. You can try pulling the IOD fuse but you still have to take off most of the air filter stuff to get to the PDC so it's just as easy/hard to get to the battery cable.
Old 22 Apr 2013, 11:00 pm
The IOD fuse will do one of two things. It will reset the ECM, or it will toast the IOD fuse. Usually your supposed to disconnect the battery before playing with large fuses anyway haha
Just write down your presets :-D takes 3 minutes and a lot less of a pain then getting to the motor fuse box lol
Old 22 Apr 2013, 11:47 pm
its not so much the radio staions it's more the sound settings that I didn't feel like messing with. I really just being lazy. A friend of mine, who is into Srt 4's told me there was a fuse he knew of but it looks like their fuse box is a little different under the hood.
Lenny
Old 22 Apr 2013, 11:58 pm
Send a message via AIM to mole
ASD 20 amp fuse
it will reset the PCM
Mole'@DCR
2004 SRT-4 built
2005 SRT-4 mole' 16g bws setup. 380hp 444tq 11.7@122 100% stock motor/head/axles. Dsp tuned.
2003.5 MazdaSPEED Protege stock
2004 PtGT Atx BWS SETUP and a few bolt ons. stay tuned for dyno #s
Contact me for all your BWS/DCR needs..........
Old 23 Apr 2013, 12:22 am
Originally Posted by mole View Post
ASD 20 amp fuse
Is that under the hood?
Lenny
Old 23 Apr 2013, 12:55 am
yes sir it is.
Mole'@DCR
2004 SRT-4 built
Old 23 Apr 2013, 01:10 am
I thank you for your help. I've got new wires,plugs,brakes(front and rear),K&N air filter, stage 2 injectors and a rescale tune to install this week(most likely Friday) Not to mention I made myself a boost leak detector that I know I need to use. So I will be needing to reset the computer for sure.
mole likes this.
Lenny
disconnecting battery gonzomania Tech & Performance Forum 10 06 Jun 2013 10:40 am
Arm Rest Power Outlet Russellhold Interior Accessories Forum 7 05 Feb 2010 11:00 pm
change console with arm rest jinky Interior Accessories Forum 5 03 Oct 2008 05:57 pm
Passenger Arm Rest.... 2k1PT Interior Accessories Forum 2 30 Jun 2007 07:24 am
Disconnecting battery cable TaylorMade Tech & Performance Forum 6 08 Aug 2004 11:24 am
