Hi Flow Cat
Old 13 Mar 2004, 12:45 pm
Default Hi Flow Cat
I understand that the biggest restriction on the PT is the cat converter. Dose anyone know where to find a hi flow cat.
Thanks
Old 13 Mar 2004, 07:35 pm
Blade,
I've seen them advertised at some of the muffler shops back in Maryland where I used to live. Check a couple of them out in your neck of the woods.
Old 13 Mar 2004, 10:06 pm
Here's some, "univeral fit", pretty cheap:
http://www.flatlanderracing.com/full...onverters.html
I would think the one for the turbo is bigger (but don't know for sure), so if yours isn't a turbo, might want a turbo cat.
Old 15 Mar 2004, 07:31 pm
I had a muffler shop install a dynomax hiflo with a bung for the 02 sensor on it after I installed a JBA header. Works good and sounds even better. A little more pull than the stock ex & cat. The only reason I changed it was because the stock cat was leaking and coming in the car.
I would have left it stock but the factory cat was $750.00 from the dealer. Header & Dynomax cat was cheeper.
Later, Scott
2001 Stone White PT (Non-Turbo)
http://www.imagestation.com/album/?id=4288162929&idx=1
Click Here to see my PT!
Update on Flow Back Catch Can littleblueGT Turbo Performance 3 12 Sep 2006 09:29 pm
FLOW BACK CATCH CAN littleblueGT Turbo Performance 4 03 Sep 2006 02:18 pm
S&B HIGH FLOW AIR SYSTEM??? bigpoppacat Tech & Performance Forum 5 07 Sep 2005 01:28 pm
Flow back catch can littleblueGT General Turbo Discussions 16 30 Jul 2005 10:46 pm
Exhuast flow one sided turbomangt Turbo Performance 6 20 Feb 2004 03:05 am
