PT Cruiser Forum Car Videos
Car Rims
Engine Check Light
Old 13 Mar 2004, 02:01 pm
IRPT IRPT is offline
Default Engine Check Light
Last night my engine check light came on about 5 minutes from my house. When I got home I checked for any codes and received the following:
P0456 & P1684
I was able to find the following info only
P0456 Evaporative Emission Control System Leak Detected (very small leak)
P16XX Computer and Auxiliary Outputs
I made sure the fuel cap was on properly, then I disconnected the negative battery cable to see if anything would reset. The P0456 code went away but the P1684 remained.
Anyone have more info on the P1684 than just Computer and Auxiliary Outputs?
Anything else I should check or do?
Old 13 Mar 2004, 02:29 pm
Ant Ant is offline
It simply means your battery has been disconnected in last 50 starts.
The light should go out but it will stayed stored for a while. If you run your diagnostic check it will come up because you just disconnected the battery again; normal.
PT powered PT with:
Fully built HRC Turboed 2.4: Wiseco pistons, T2 rods, Port & Polished head (Bob Special) with oversize Stainless Steel valves, #14 Crane Cams, AF/X UDP, No balance shafts, Custom 3\" downpipe, 3\" hi flow exhaust, Ported GT intake manifold, Bored Throttle Body, 30 lb injectors, Water/Alc. injection
Old 13 Mar 2004, 02:33 pm
Thanks Ant. That's strange though, I have not disconnected my battery for several months. Could a low battery cause the same thing?
2002 Inferno Red PT Limited
Mercedes Wiki
Old 13 Mar 2004, 09:16 pm
MX-5 MX-5 is offline
Ant is correct for pre-2001 cars.
The P1684 is simply a PCM readiness code.
It means that communication between the PCM and BCM is working.
Ignore it.
Old 13 Mar 2004, 10:04 pm
Ignore it.
Thanks MX-5!
Mercedes Wiki
Old 13 Mar 2004, 10:16 pm
So it was the old "loose gas cap" problem???[:I]
Old 14 Mar 2004, 05:15 am
Not sure. I undid the gas cap and re-installed it, then I disconnected the battery negative cable for about 40 min. When battery cable was re-installed the 0456 code was gone but still had the 1684. When out and checked it a couple of hours later and received no codes.
Mercedes Wiki
Old 06 Jun 2004, 04:40 pm
kcgal kcgal is offline
I am getting error code P0601 and P1684 on my 2001 PT Cruser....does anyone know what those codes mean....or can anyone refer me to a listing of codes? My engine light is on; taking car to dealer tomorrow. Thanks, Kay
Old 16 Jun 2004, 11:28 pm
cavynmaicl cavynmaicl is offline
Send a message via AIM to cavynmaicl
[:I] Ok, I have the engine light on, but no codes... I've run the diagnostic a few times, and gotten no codes, everything seems to be fine, but the engine light stays on... any thoughts? I'm at a loss...
Old 26 Jun 2004, 10:42 pm
richg richg is offline
Hi, Have a 2001 with engine light on and no codes. Transmission stays in 2nd gear. Any ideas....
Regards, Rich
vB code is On
Check Engine Light CHROMEDCRUISER General PT Cruiser Discussions 11 16 Jul 2008 11:46 pm
Faulty Check engine light? Mel K General Turbo Discussions 5 23 Mar 2007 10:06 am
Check engine oil light question AaronR General PT Cruiser Discussions 5 28 Aug 2004 03:18 am
Clearing check engine light Blade Tech & Performance Forum 10 27 Mar 2004 01:48 am
"Check Engine" idiot light on AGAIN tezz General Turbo Discussions 11 10 Jul 2003 04:55 pm
  MPAA | Mobile Phones | MPAA | Free Engineering Ebooks | Loans
