Earth straps
Old 12 May 2013, 12:12 pm
Default Earth straps
I notice that both earth straps from the bodywork to the front hub assembly are broken on my 2001 PT. I need to repair these obviously, but what effect, if any, will they have on the car.
I realise that they are probably there to remove any static build up but apart from that what symptoms would I see with these broken?
Old 12 May 2013, 12:22 pm
Default Re: Earth straps
Here ya go, everything you always wanted to know about the ground straps and probably a bit you didn't want to know either.
ground wires from body to front struts?
Old 12 May 2013, 12:38 pm
Thanks Crewzin
I sort of wished I had not asked now
Looks like I should fix these wires sooner rather than later.
Old 12 May 2013, 12:45 pm
I don't know.
You will be told here that without the ground straps, wheel bearings wear out faster.
Green Earth Technologies NeosCruiser General PT Cruiser Discussions 3 27 Aug 2012 04:14 pm
Elastic Straps compdr59 PT Cruiser Convertible Forum 7 08 Apr 2012 09:30 am
Decklid and Elastic Straps compdr59 PT Cruiser Convertible Forum 2 08 Jan 2012 08:23 am
Front Ground Straps sscanlan Wheels, Tires, Suspension 19 26 Mar 2011 09:54 pm
