PT Cruiser Forum (http://www.ptcruiserlinks.com/forum/)
-   Tech & Performance Forum (http://www.ptcruiserlinks.com/forum/tech-performance-forum/)
-   -   Windshield Wiper Problems (http://www.ptcruiserlinks.com/forum/tech-performance-forum/48768-windshield-wiper-problems.html)
NewPTCruiserInPA 27 May 2013 11:30 am
2006 base PT with 122K.
My windshield wipers have been acting up more lately. I first posted about them in May '12, how they would turn on by themselves if I made a turn, or if I turned on the turn signal. After our power steering was replaced two years ago, the problem became more frequent, but still not constant. You'd just have to turn them off when they turned on. They also seem to act up more when the weather changes.
Recently, they have been acting up more, and are more difficult to get off once they are on.We didn't drive the car between Thursday night and Sunday afternoon. My husband turned them on to clean the windows and forgot to turn them off before turning off the engine, and today, they will not turn off at all! They were in the on position, but would not stop when turned to off. We had a 10 minute trip out and made sure they were off when we got out, but they still came on by themselves when we got back in.
Someone had mentioned the ground wires or the MFS. Could one of these be the problem considering the problem has occurred for so long? I hate to take it to the dealer (we are not car savvy). Like all of our weird auto problems, I'm sure it won't replicate and they'll just charge me for whatever they think it could be, it won't be that, and the car will still do it...
NewPTCruiserInPA 30 May 2013 05:33 am
Re: Windshield Wiper Problems
I made an appt with the dealer to check out the windshield wipers for Friday, and in the meantime, I had my husband try and adjust the steering wheel differently to see if that would have any change. He lowered it a bit, and it did nothing, they still stayed on. Then he tried raising it a little higher than he previously had it, and he was then able to turn off the wipers!
What does this sound like?
soyomb 30 May 2013 12:47 pm
the wiring is pretty tight in the column. when the steering is lowered there's been things such as radio illumination dimming, horn not working, etc.
i would leave it raised enough to where the wipers continue to work. not sure if there's been a fix for this dilemma.
NewPTCruiserInPA 31 May 2013 08:11 am
Raising the steering column up got them to turn off, but at least one time since then, they came on by themselves when first turning on the car and then turned themselves off. I've not tried to use them since then because I didn't want them to get stuck back on.
Have it at the dealer today, and they said it's a bad switch. They have it in stock, so I opted to replace. $250. Sure wish I knew how to work on cars myself!!
soyomb 31 May 2013 11:27 am
that's a shame. the part is right around $50 and it's very simple to replace. check the "how to" in the tech section.
i absolutely hate the way dealers rip people off.
dougs 02 Nov 2014 12:15 pm
Now with the first rain of the year, the wipers in our 2006 base would not shut off. There is no fuse to pull, so that was no help. In frustration I banged on the end of the wiper stalk with the ball of my fist a couple of times, and .... bingo! The wipers shut off. So there must be a worn connection or some sort of short in the wiper control/switch in the steering column... that's my guess.
LionPT 02 Nov 2014 01:02 pm
Did you turn them back on afterwards, do they still work..??
hotrodbobby 05 Dec 2017 06:34 pm
Hi guys ! My wipers are playing up as well. Sometimes they work fine, then they wont do anything apart from switch to the fastest speed and I have to park them by luck
Handy_Cruiser 05 Dec 2017 07:00 pm
In most cases, this is going to be the multi-function switch. Of course, it could be something else. But on the PT's this is usually it. ;)
ptcruisersteve 05 Dec 2017 07:50 pm
A wiper system has some interesting design elements. There's a "park switch" in the wiper motor that senses when the wipers are in the park position. When you turn the wiper switch off, the "park switch" keeps the wiper motor running until the wipers are in the park position, then the "park switch" shuts off the wiper motor.
For continuous operation, the wiper switch applies power to either a low speed winding in the wiper motor or a high speed winding.
The intermittence of the windshield wiper is controlled by the TIPM.
If you are having trouble parking the wipers I would suggest checking the park switch in the wiper motor.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240
