Power flush vs. drain/fill for tranny.
Like Tree4Likes
  • 1 Post By cruserdad1976
  • 1 Post By Busted_PT
  • 2 Post By nomad327
Old 28 Jun 2013, 02:01 pm
Default Power flush vs. drain/fill for tranny.
I've read things on PT forums about it being bad to have your tranny power flushed. Pushing contaminants into small passages in the transmission. Wondering what everyone's opinion is on this. I have the auto stick GT and I'm due for this service. I've had flushes done on other vehicles in the past with no problems but want to be safe with my GT convert.
Old 28 Jun 2013, 03:36 pm
UptownSport's Avatar
Default Re: Power flush vs. drain/fill for tranny.
My suggestion is to follow owner's manual.
Old 28 Jun 2013, 04:28 pm
cruserdad1976's Avatar
kind of up to you its around $175 for a power flush in my area
you can drop the pan change 5 quarts of ATF 4 and a filter for about $70
thats only about half the fluid but to me it has to be better than nothing you get a new filter clean the magnet and have 5 quarts of fresh fluid'
do it again in a month and its pretty close to a full flush
the other thing si with out a rack its kind of messy so think of that as well
Busted_PT likes this.
Old 29 Jun 2013, 07:37 am
Another thing, if they don't pull the pan on the flush then you still have a dirty filter and pan. The filter is more important than the fluid. On the regular change, the fluid still in the trans is filtered and clean. So know worry's there. One won't make the trans live longer over the other if the filter is getting changed on both. So your call.
cruserdad1976 likes this.
Old 01 Jul 2013, 01:49 pm
One thing with a transmission flush is the machine must have the correct mopar fluid in it. A good flush with the incorrect fluid would do more harm than good. I pulled my pan and welded a drain plug into it. I changed the filter at that time. With the drain plug, I get almost exactly 4 quarts which is half of the total and it only takes a minute after the first time. I change out a gallon like this probably once a year.
Tranny Flush FanDroid General PT Cruiser Discussions 27 18 Nov 2011 08:36 pm
Transmission drain and fill issue!!! 2002ptcruiserwoody723 Tech & Performance Forum 10 01 Oct 2009 09:02 am
Do it urself tranny flush / filter change ? CYCLONE_06 General PT Cruiser Discussions 3 27 Sep 2009 05:20 pm
MOPAR ATF +4 Drain & Fill How Many Quarts? lmmegt Tech & Performance Forum 13 23 Sep 2009 07:30 am
Coolant Drain & Fill Help lmmegt Tech & Performance Forum 3 07 Sep 2009 10:11 pm
