2005 PT - odd starting issues
Old 28 Jun 2013, 05:07 pm
OpenCar's Avatar
Default 2005 PT - odd starting issues
Greetings! New member here - I have a 2005 PT convertible - went to start it last week and the following happened:
- Clutch in, turn the key - nothing. Heard the fuel pump kick in, but that was it.
- About 6 hours later, tried it again - cranked, started and ran for a few seconds, died. Did this a cpl. of times
- About an hour later, tried again, fired up on the 1st turn of the key.
Anyone else have issues like this? Had the car about 1 month - I'm thinking the clutch start switch may be possessed. ANy way to bypass that absolutely useless item? ANY help is appreciated!!
Old 28 Jun 2013, 06:05 pm
Default Re: 2005 PT - odd starting issues
Sounds like a key thing . Especially the stare and run and die thing.
Old 28 Jun 2013, 06:25 pm
OpenCar's Avatar
Interesting - I was just out in the garage - think I've eliminated the clutch switch as the culprit.
Do tell me about this key thing you speak of - I am pretty mechanical, but new to the PT Cruiser. Ignition issue?
Old 28 Jun 2013, 06:39 pm
OpenCar's Avatar
So, it started for me, ran fine. Went back out, start, run, die. Ugh.
Old 28 Jun 2013, 06:41 pm
randyincctx's Avatar
Lightbulb Re: 2005 PT - odd starting issues
Could be as simple as a worn ignition switch........Does there seem to be an unusual amount of play in your ignition cylinder? (i.e....Can you jiggle it,or push it in alot)
Aka:~KILLER~
Old 28 Jun 2013, 06:56 pm
OpenCar's Avatar
Doesn't feel excessively sloppy.
Old 28 Jun 2013, 07:55 pm
OpenCar's Avatar
Do you mean the ignition switch or the ignition cylinder?
Old 28 Jun 2013, 09:17 pm
Both;The cylinder may be worn and/or the switch may be worn too/also.....Either one could cause that problem if it's a simple fix.......If it's not;Intermittent starting/cranking can sometimes be pretty tough to track down,but by the same token the circuit is pretty simple.......To do real testing, you may need a voltmeter on hand for those times it won't start to verify you have power at switch,the relay,and at the solenoid.
Aka:~KILLER~
Old 29 Jun 2013, 06:02 am
OpenCar's Avatar
Thanks for the info. Randy - very much appreciated. New switch and cylinder going in today. Just started vacation and want the top down if it ever stops raining!!
Old 29 Jun 2013, 02:35 pm
OpenCar's Avatar
OK - new switch and cylinder resulted in key in ignition chime pinging when just the door was open, no key. And it wouldn't start, then wouldn't even crank. Put the old ones back in, fired right up. Changed the plugs and did notice the plug wires were not snug on either end. It's running now, but we shall see. Anyone with ideas, experiences or suggestions, please, PLEASE contact me. Would like to solve this. Thank you!!!
Starting Issues - please help selkov Tech & Performance Forum 5 10 Sep 2013 09:15 am
Starting issues ... *sigh* nickdel Tech & Performance Forum 20 07 Feb 2013 01:35 am
Starting Issues pinoyPT General PT Cruiser Discussions 8 23 Nov 2012 06:19 pm
pt starting and driving issues 05pt_cruiser Tech & Performance Forum 0 16 Jan 2012 10:21 pm
Starting Issues Need Help!! 01 PT Manual cusunfireguy General PT Cruiser Discussions 8 31 Jan 2011 03:19 am
