2006 PT Cruiser - Radiator Help
Old 01 Jul 2013, 12:02 am
Default 2006 PT Cruiser - Radiator Help
Notes/Specs
- 2006 PT Cruiser manual transmission
- 180,xxx miles
- Replaced radiator fan recently(Was completely dead)
- When replacing fan, noticed hoses/clamps were in pretty bad shape and the radiator itself was leaking slightly.
- Ordered new clamps, upper/lower hose.
Now here is my dilemma. I ordered this radiator More Information for TYC 2298
If you notice near the bottom are the nipples/connections for what I assume either the AC hoses and or transmission cooler?
Edit: Think I got it figured out... The nipples at the bottom of the radiator are for an Auto transmission? I just need to remove the AC lines bracket that are on the passenger side?
Old 01 Jul 2013, 08:27 pm
Default Re: 2006 PT Cruiser - Radiator Help
nipples are for auto trans leave capped - then ac lines - fan hookup - make shure you replace thermostat and cap - pressure test system when done - they have multi layered steel head gaskets - very sensitive to overheating! hope this helps
Removing - Replacing Radiator Fan 2006 PT Cruiser Base Model CashReject Tech & Performance Forum 4 31 Oct 2011 12:57 pm
2006 radiator fan kit Sc19881 Tech & Performance Forum 6 11 Aug 2011 09:03 pm
2006 PT overheating after radiator flush jpassons Tech & Performance Forum 10 13 Jul 2011 05:19 pm
2006 Radiator replacement Samson Tech & Performance Forum 10 06 Nov 2010 09:19 pm
Wanted: radiator for 2006 PT non-turbo Samson Classifieds: Want To Buy 2 06 Nov 2010 03:20 pm
