110 degree weather overheating w/AC on?
Old 01 Jul 2013, 06:52 pm
Default 110 degree weather overheating w/AC on?
car: 2003 PT touring
weather: Summertime Heatwave(today 110-114 degrees)
new parts: Radiator Fan
Is it normal for the PT to go a little over the half mark on the temp gauge (a little under the 3/4 mark) with the AC on??? The temp gauge starts to climb up between 105-110 degree weather, but anywhere under 105 degrees the temp needle goes back to half mark.
Old 01 Jul 2013, 07:06 pm
Question Re: 110 degree weather overheating w/AC on?
What does it read with the AC off?
Old 01 Jul 2013, 09:13 pm
Default Re: 110 degree weather overheating w/AC on?
With the AC off, the needle goes back to normal(half way mark) with it idling for 10-20 minutes *tested.
Other than that, when I have the AC on and i'm stopped at a light with an outside weather of over 105 degrees, the gauge temp starts to climb.
Old 01 Jul 2013, 09:20 pm
PhxPT's Avatar
Sounds like one of the fan relays or the fan itself has gone out for the high-speed. I had the same thing happen to mine and it was a bad fan
Oogway - Aquamarine 2001 PT Cruiser Limited
Alpine iDA-X200 DMR headunit w/ Sirius Satellite Radio
Old 01 Jul 2013, 09:25 pm
It's a brand new fan, not even two days old.
When I cold start the car and turn on the AC, low speed comes on.
I wait till car fully warms up with AC off... smoke a cigarette while i'm waiting in front of the car till I hear the high speed come on. So no, it cannot be the fan/relay.
*I've also fully bled the coolant system after fan install.
Old 02 Jul 2013, 04:00 pm
bump.
Old 02 Jul 2013, 04:41 pm
cruserdad1976's Avatar
did you replace the theromstat?
did you do a rad flush???
last year here in missouri we had that kinf of heat and mine would stay right on the half way mark
but really as long as it never goes higher its probaly ok
Old 02 Jul 2013, 07:29 pm
The needle goes above the half mark almost near the next line on the temp gauge. I replaced the thermostat and did a radiator flush about almost a year ago. I'll see if replacing the thermostat would do the trick or flush it again.
Thank you
Old 02 Jul 2013, 11:58 pm
First I have to LOL at the responses from the members that do not live in our area right now. I am in Lincoln CA BTW! Hit 117 over the weekend.
Next invest in an Ultra Gauge it will be the best single investment you can make for your PT.
And as for the temperature gauge raising slightly above the middle position in our area of California right now if you are driving anything but an easy 55-60 mph the gauge with AC on will climb above the mid way point.
You need to start to worry if you get close or at the 3/4 mark on the gauge.
Reading the responses by you from other members comments IMO you did everything correctly and I doubt you have any problem? If you are anywhere close to me pm and I will give you me address you can bring your PT by and i can check it out for you.
Once again take a moment and look at the Ultra gauge for something to have in your PT. If you had one you would feel better about what is going on with the coolant and also be able to know of concerns before they get to the point of damaging something?
UltraGauge OBDII Scan tool & Information Center
UG in a PT
PT Cruiser custom mount
Old 03 Jul 2013, 04:25 am
lou; sounds like your radiator has reached it limit of cooling capacity. A flush might help, but a new radiator would be better, especially if you could buy one with a higher cooling capacity. Or, you could move?
180 degree thermostat question moparbbad Turbo Performance 11 20 Jun 2015 08:02 pm
90 degree vs straight plug ends saldagus Tech & Performance Forum 3 23 Jan 2010 10:57 pm
180 degree coolant sensor sjmx22 Tech & Performance Forum 3 02 Aug 2009 04:52 pm
All Weather Tires mikmad Turbo Wheels/Suspension/Handling 5 01 Oct 2007 04:03 pm
Weather Stripping PT 7 General PT Cruiser Discussions 1 20 Apr 2002 09:46 am
