new ignition switch problem
Old 02 Jul 2013, 01:06 pm
Default new ignition switch problem
Hi everyone. im new here. 2004 chrysler pt cruiser base model. i just replaced my ignition switch and ignition switch actuator pin. before this the car would only beep when the door was open with the lights on or with the door open with the key in the ignition. now my problem is the car beeps when the door is open even with the key out and the lights off. i have read somewhere that the pcm is constantly adjusting to changes in your vehicle. so is this something that will correct itself after a few trips or is there something i can fix or do to return it to the old beep warnings??? thanks for any that help
Old 02 Jul 2013, 01:11 pm
Default Re: new ignition switch problem
i believe that has to do with the brass part on the ignition actuator. i recommend playing with that while also playing with the key to see if you can sort it out.
Old 02 Jul 2013, 01:20 pm
thank you. i will definately give that a try
Old 03 Jul 2013, 05:20 am
Pluto is a dog star.
Tags
actuator, beeping, ignition, pin, switch
Ignition switch lt4supr Tech & Performance Forum 10 21 May 2016 06:28 pm
Ignition Switch Problem? jjensen101 General PT Cruiser Discussions 8 11 Apr 2013 07:15 pm
possible ignition switch problem skisbabe Tech & Performance Forum 3 02 Oct 2012 01:41 pm
Ignition Switch BMAC1206 General PT Cruiser Discussions 10 22 May 2012 03:27 pm
Possible Ignition Switch? bkarr Tech & Performance Forum 4 20 Jul 2008 06:25 pm
